Re: Drive shaft options for a 74 B body?
[Re: 74RALLYE]
#2122517
08/01/16 11:47 AM
08/01/16 11:47 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Are you using solid U joints? the kind with no zerk fitting or lube passageways drilled in it?
I never broke a U joint with my 64 300, similar build but a warmed 413 and wider tires compared to your build. I did rip the ear of the yoke on the rear end though, but that was with the 4.10 gears I put in place of the 3.23's it had.
[Re: 74RALLYE]
#2122664
08/01/16 03:05 PM
08/01/16 03:05 PM
Supercuda
About to go away
About to go away
up yours
Depends on if you have the small or large U joints, Rock auto shows several vendors for the smaller one.
Spicer 5811X seems to be the only option for the larger one at RA.
[Re: 74RALLYE]
#2122722
08/01/16 04:22 PM
08/01/16 04:22 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
gotta be something wrong with your drive line angles. I had a '74 Challenger, 440/4spd, 8 3/4 SS springs the car runs 11.7's all day with stock small u-joint driveshaft, small in the front, crossover u-joint in the back. I broke axles and rears before, but never a u-joint. are you sure everything is lined up correctly? watch this, https://www.youtube.com/watch?v=gmV4qwLfOMY
[Re: 74RALLYE]
#2128926
08/09/16 08:34 PM
08/09/16 08:34 PM
Posts: 4,213 New York
polyspheric
New York
X2
Boffin Emeritus
[Re: 74RALLYE]
#2128928
08/09/16 08:37 PM
08/09/16 08:37 PM
Posts: 20,228 Park Forest, IL
slantzilla
Park Forest, IL
What's in it for springs and shocks?
