small cap hei for small block #2121504
07/30/16 08:21 PM
07/30/16 08:21 PM
Martin TN
ridin98ci Offline OP
Martin TN
I have the small cap assault hei and coil for my 318 in my 71 charger.....I have no instructions for it and they don't include any on their website.....has anyone installed one of these before? I need help
LOUD AND PROUD!!!
Re: small cap hei for small block [Re: ridin98ci] #2121601
07/30/16 11:21 PM
07/30/16 11:21 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Never even heard of them before...is it some sort of china copy of something I could imagine?
What sort of module does it use? If it is a 4 pin GM style, should be easy to google imagine search for a wiring diagram of it.
Re: small cap hei for small block [Re: ridin98ci] #2121655
07/31/16 12:20 AM
07/31/16 12:20 AM
post a pic of it if you can
Re: small cap hei for small block [Re: ridin98ci] #2122155
07/31/16 08:47 PM
07/31/16 08:47 PM
Martin TN
Martin TN
I was wrong its a procomp set up.....Ill see if I can figure out how to log on from my phone to get a pic
LOUD AND PROUD!!!
Re: small cap hei for small block [Re: ridin98ci] #2122424
08/01/16 05:09 AM
08/01/16 05:09 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
red wire to hot side of coil...black wire to negative side of coil...make sure coil is getting full 12 volts...remove ballast resistor and connect those two wires together..and run another wire to hot side of coil to provide the full 12 volts..
got one in a 88 dodge d250 runs great..
Tony
70 AARCuda Vitamin C
Re: small cap hei for small block [Re: ridin98ci] #2122430
08/01/16 05:47 AM
08/01/16 05:47 AM
Martin TN
Martin TN
Thank you sir!!
LOUD AND PROUD!!!
