Re: Organosol "The Bulletin" January 15, 1969
[Re: RoadRunnerJD]
#21234
01/26/06 06:20 PM
01/26/06 06:20 PM
Just tried ordering the Organisol from Totally Auto and the lady said that 1968-1970 Chargers were a smooth finish and was just a semi flat black paint. Kinda contradicts what the TSB attachement says.
[Re: JeffsCustomPaint]
#21239
03/27/07 05:30 AM
03/27/07 05:30 AM
Posts: 6,301 colorado
a12superbee
colorado
Thanks for posting those Jeff. Do you have any shots close up that might show the texure you achieved using this technique?
I can't afford this.
mark
[Re: a12superbee]
#21241
03/27/07 09:38 AM
03/27/07 09:38 AM
BradH
Same here... because it doesn't look like it has any texture at all in your pictures.
[Re: BradH]
#21242
03/27/07 09:50 AM
03/27/07 09:50 AM
Posts: 5,160 Texas
dannysbee
Texas
Jeffs hood looks like the hood of my R4 Bee I got in 74.
Getting old just means you were smarter than some and luckier than others.
[Re: cataclysm80]
#21246
10/18/07 03:07 PM
10/18/07 03:07 PM
Posts: 21,528 N.E. OHIO, USA
A12
N.E. OHIO, USA
Tav
Don't wait for me, I originally posted this December 17, 2005 and Jeff dug it up and it to the top. If I were painting an AAR, T/A hood or an A12 Lift-Off-Hood I would seriously look into this "Note";
NOTE: Engine exterior area of hood to be painted with 2183385 Exterior Air Dry Organsol Paint AX5DX8 Black, prior to installing hood retaining parts. 1-16-69
Painters out there, does this make any sense? Are the paint codes still relevant?
MikeR
I'm with you on this
BTW Tav, you seem to be waiting for something (from me?? ) in another few re-posts of mine, anything I can do to help let me know because I'm a little
MikeR
[Re: A12]
#21249
10/18/07 09:15 PM
10/18/07 09:15 PM
Posts: 2,908 Franklinville,NJ
JeffsCustomPaint
Franklinville,NJ
I originally posted this December 17, 2005 and Jeff dug it up and it to the top. MikeR
Mike i read that this thread was mentioned in Lon's thread about his hood and i seen that some people wanted to see pics of the hood i did upclose and they were after i last posted so i responded to that not to really dig it out and bump it but it is a good thread and people still need to do the organosol but sometime can't find info on it. It's a good thread to save
#21250
10/18/07 09:46 PM
10/18/07 09:46 PM
A12
N.E. OHIO, USA
Jeff, I'm happy that it came back up, I was just kind of responding to the from Tav, like someone was waiting for the other shoe to drop from me MikeR
[Re: QuickSilver]
#21251
10/18/07 10:01 PM
10/18/07 10:01 PM
A12
N.E. OHIO, USA
Not sure if this helps but that AX5DX8 black seems to be an actual factory< in house> paint code. I know from working in the chrysler facility I was stationed at all of our quart cans and gallon cans of paint material all had an extra label secured over the original along with extra paint codes on it. This was to reduce the amount of lunch pail theft as you weren't really sure of what you were taking without peeling the outside label off. Just a thought. My paint supplier told me that the only codes for organisol in his books from 1969 were the 9355 which probably is correct for doing the rocker blackout as well as the tail panels for chargers etc. as listed on that TSB. He did give me another product which I had forgotten about which is called High Performance Black DDL 9381. That number has been changed to DDL 9423. I remember painting the glass hood for my dads T/A Challenger with this years ago and it seems like it might be the right stuff. I am going over to his shop and look around and see if I can find that gallon can. Has anyone tried using the DDL9423?
Joey, for sure that is the factory paint code (AX5DX8) for the A12 hoods (and maybe the AAR/T/A too?) and then the 9407 was from memory by a good friend and excellent source and he may be off on the last two numbers because he used the "94" several times until he settled for 9407. The DDL9423 may be the "missing link" for the closest match to the hood paint
MikeR
[Re: A12]
#21252
10/18/07 10:09 PM
10/18/07 10:09 PM
Posts: 6,252 Zzyzx Road
beepbeep
moparts member
moparts member
Zzyzx Road
None of the Organosols today are anywhere near the originals, both the metallic and suede used originally is no longer available.
9381 is a Ford color that was used on the shaker hoods and scoops.
Amazing how an unchallenged lie can become the absolute truth.
[Re: beepbeep]
#21253
10/18/07 10:29 PM
10/18/07 10:29 PM
A12
N.E. OHIO, USA
August 30, 2007 Authentic Restoration Products from Roger Gibson Auto Restoration E-mail: sixpackfrank@aol.com Web: www.rogergibsonautorestoration.com
ORGP/ORGQ Organosol - authentic black textured finish for hoods, tail panels…………Qt $95.00 ***ONCE AGAIN AVAILABLE*** .................................Pint $50.00
I'm pretty sure this is the latest version and not from the original supply that was supposedly around for a while. Anyone talk to Frank lately about it?
MikeR
