Page 1 of 11 1 2 3 10 11
76 Volare, yes a volare. #2116859
07/24/16 09:41 PM
07/24/16 09:41 PM
west palm beach, florida
modelmakerinc Offline OP
Well, since I sold my Volksrod and my Coronet is in the tedious process of block -sanding plus waiting a big cube bullet.
I bought myself a cheap throw together type project. Every B-body that I looked at was way too much of a buy in, and I had no spare parts for an A-body so I got a pair of 76 Volares'. One is ok the other is toast but has some good useable and needed parts.
Pics coming
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2116912
07/24/16 11:17 PM
07/24/16 11:17 PM
Pics of how it arrived. The landau quarter windows will be swapped to the standard glass.
I will be making it a Day 2 tribute to the 70's street car. Without the phsycadelic (sp) paint job.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2116948
07/25/16 12:10 AM
07/25/16 12:10 AM
Fitting in a 400 & 727 and I used a set of B-body SS leafsprings and a 8-3/4. I rebuilt spring packs using the F body main leaf and the isolaters went away with the swap.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2116965
07/25/16 12:27 AM
07/25/16 12:27 AM
Here are the mods done to the driver side motor mount as per Schumacher directions, with considerable more mods than they say.
The power steering box is getting swapped for a manual so i had to make the extention. The brake booster is going to be from a 75 Dart which is smaller in diameter to clear the big block valve cover.
The engine compartment is stripped of everything, and k frame will get cleaned up before reinstall. Lots of scraping cleaning then some paint.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2116985
07/25/16 12:42 AM
07/25/16 12:42 AM
I'll be making steel blocks to replace the shabby isolaters, I am going to rebuild the suspension once the car is complete again. I think it will be easier with the k frame mounted and above me on a lift.
The car was considerably rustier than the seller disclosed so I had to patch the frame rails and will be doing the floors soon.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2117929
07/26/16 08:48 AM
07/26/16 08:48 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
That will make a nice ride. up
Used to be a black R/T or RR (decals removed) w/ Centerlines near me. Sounded very healthy and looked very good. Never had the chance to stop by and talk to the guy.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2119228
07/27/16 06:45 PM
07/27/16 06:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wow , that was the good one? I can only imagine what the other one looks like .
Have fun , looks like a great project.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2122189
07/31/16 09:49 PM
07/31/16 09:49 PM
Was able to fab and weld up my steel isolaters blocks, I decided to make them a little shorter than the originals.
They are supposed to be 1-5/16 but I used two 5/8 thick blocks with a 3/4" through hole, I welded them together and added a modified flat washer to make the locating tab.
New grade 8 hardware is shorter since there is no isolaters on the bottom of the k frame
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2122193
07/31/16 09:51 PM
07/31/16 09:51 PM
In place, I will paint them and the k member before re install.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2129862
08/10/16 10:18 PM
08/10/16 10:18 PM
I'm not really going to put alot of horsepower or sticky tires or a steep set of gears, but since it needs some floor work I figured I would install frame connectors.
I used .125 wall 2" square tube, I did a lap joint on the front and matched the framerail on the rear
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2141021
08/25/16 11:53 PM
08/25/16 11:53 PM
Since this car will never be worth too much, I am cutting a few corners and saving weeks of work and lots of money in some of the repairs I do.
The cowling had many holes, and overall was paper thin in alot of it. Seems the paint never reached the obscured areas so in rusted out pretty good.
There is no way I would cut the upper cowl off to properly replace the lower, so I opened up the cowl a bit and sand blasted the entire area, I used an epoxy laminating resin to coat and layup the entire cowl area, kinda like a full tray and then a coating of flex seal liquid to protect the resin.
I'm sure I'll hear blasphemy from someone for the way I fixed it, but otherwise the car would not be saved.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2141024
08/25/16 11:57 PM
08/25/16 11:57 PM
And so I don't spend a day driving to the steel shop for sheetmetal, I procured a bit from elsewhere
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2141195
08/26/16 10:46 AM
08/26/16 10:46 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I did the same thing to my 76 Volare in 1988, I used a 440, Headman E body 2" headers and fabbed solid motor mounts. The car was new enough at the time I was able to get new quarters and a grill from mopar, with a little trimming on the front i can get a 30 x 10.5 to fit. If you want to save about 300 lbs make bumper brackets to replace the crash bars and energy absorbers at both ends.
I got my Volare for $150 from the back row of a chevy dealer, 73k on the clock.
Have a great day
Iowan
"obsolete is neat"
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2143367
08/29/16 09:15 PM
08/29/16 09:15 PM
Floors are patched, not pretty, but solid. Guys be thankful to have replacement panels for your common bodystyles.
because cutting & bending flat stock to fit sucks
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2147826
09/05/16 07:46 AM
09/05/16 07:46 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Wow Henry nice job bro, i didnt realize how much work youve been doing on it.
dont get too carried away, i know the fabrication of the build is what you really enjoy but try to remember, its to be a fun driver not a show car wink ha ha ha.
(since Dan @performance only (RIP) isnt around anymore, someone need to pick on you to keep you in check.)
copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2162068
09/26/16 03:04 PM
09/26/16 03:04 PM
After a couple weeks of working on other things I was able to dedicate a few days to the engine compartment.
First I did the bodywork to the repaired rusty areas on the firewall, then stripped the paint off the rest of the panels, primed with metal etch, and a bit of rattle can high build primer, sanded it completely then COLOR
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2162073
09/26/16 03:08 PM
09/26/16 03:08 PM
Here are the shots in primer. These cars are seriously crap bags when it comes to the sheetmetal stamping and assembly.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2162076
09/26/16 03:11 PM
09/26/16 03:11 PM
We Got COLOR, LOTS OF GREEN. Sassy Grass, to be specific.
Single stage.
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2162079
09/26/16 03:12 PM
09/26/16 03:12 PM
Couple more
Re: 76 Volare, yes a volare. [Re: modelmakerinc] #2162609
09/27/16 09:04 AM
09/27/16 09:04 AM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
They do look good in Sassy Grass green......
