stripped thread on Holley outboard 2 bbl float bowl
#2121874
07/31/16 01:15 PM
07/31/16 01:15 PM
Posts: 333 Forest Lake, Minnesota
superbeejim
Is there any good fix for a stripped out sight bowl thread on outboard carb on 6 pk set up? thanks
Re: stripped thread on Holley 2 bbl
[Re: fury4speed]
#2122160
07/31/16 09:05 PM
07/31/16 09:05 PM
superbeejim
If you do not have to use it again for the fuel level I have used JB weld , if you have any threads left or if the plug will tighten a bit JB weld will work or just buy another bowl.
who sells the float bowls,all I see are ones with the fuel inlet on the drivers side.thanks ahead, Jim
Re: stripped thread on Holley outboard 2 bbl float bowl
[Re: superbeejim]
#2122486
08/01/16 11:04 AM
08/01/16 11:04 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Hey what the ??? where did that picture of the needle/seat hole go ??
I tried form a thread , it didn't work well , I filled the hole with JB Weld and redrilled and tapped , not sure if gasoline with ethanol in it is a place for epoxy , I think a new bowl is in your future ...
[Re: superbeejim]
#2122487
08/01/16 11:05 AM
08/01/16 11:05 AM
JohnRR
U.S.S.A.
Are those oversized sight hole plugs Bill ?
[Re: superbeejim]
#2122566
08/01/16 01:12 PM
08/01/16 01:12 PM
JohnRR
U.S.S.A.
That's what I need! Where do I get them? From Bill ...
[Re: JohnRR]
#2122724
08/01/16 04:23 PM
08/01/16 04:23 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
That went away because I didn't read the question correctly,I "ASSUMED" !! Here it is,you can fix most anything !.
