Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Kern Dog] #2134103
08/16/16 03:03 AM
08/16/16 03:03 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I did plenty of testing and tuning with my Charger. All on the street though. A track would certainly highlight more flaws since things like oversteer seem to be exponential with speed!
From 1984 to 2002, I messed around with a couple of second gen Camaros. They used the same suspension as the same year Trans Am cars so I played around with coil springs, sway bars, different bushings, etc. When I got my Charger in 2000. I did the same thing. I noticed that the front sway bar was very close to the contour of a 73-76 A body. At the time, Dusters and Darts were still common in the wrecking yards. I took a bar from some Dart and walked the yard until I found a thick bar that was similar in shape. It turned out to be in a mid 70s Chevy 2wd truck! What ???
I took the 1.25 bar and cut the ends off of it, then had a shop drill the ends to attach the end links. At this time, nobody had the 1.25 solid bar in stock on the shelf. For approx $70 including new bushings, I had a custom front bar. At first I used a 1 1/8" rear bar from a Ford truck, only because it fit the car between the frame rails. The car handled pretty good. I had stock 318 leaf springs and 1" MP torsion bars too. It still understeered at the limit but overall it was better than stock.
I later changed to the 18" wheels and tires. The front tire is a 275-40-18, rear is a 295-45-18. I added XHD leafs and switched to a 1 1/8" front bar and a 7/8" rear bar. My thinking was that reducing front roll stiffness while increasing rear stiffness should balance the car out.
Wrong.
The car now oversteered too easily! Even when coasting through turns, the rear often felt as if it wanted to come around faster than I wanted. I tried switching the rear end links to rubber on place of urethane but it made little if any difference. It was fun to drift and mess around but the thought of a spinout on the street while trying to avoid an accident worried me.
Looking at the principles to balanced handling showed me that I had a bias toward REAR roll stiffness. I figured that a safer car is one that has a slight tendency to UNDERsteer but can be made to OVERsteer with application of throttle.
I currently have a 1.15" torsion bar. I REinstalled the 1.25" GM truck front sway bar, but replaced the 7/8" rear bar with a 3/4" bar (Frame hung) from a 1983 ImperiaL. This is the same bar that can be found on most Diplomat/Gran Fury Police cars.
This combination worked great....Until I replaced the tires! I had an 11 year old set of Nitto 555s and replaced them with the same size Nitto NT01s. The oversteer is back but not as bad.
Son of a beeeeech!
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: 72Swinger] #2134829
08/17/16 12:16 AM
08/17/16 12:16 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Originally Posted By 72Swinger
I have a Hotchkis 1.5" tubular on the front and a Hellwig 7/8" E body bar on the rear of my A-body. How mix-n-match is that? Also have heims for links on the rear with modded F250 links on the front.
hey swinger how did you purchase this bar? Been waiting for them to release it but they still only advertise the 1.25" sway bar for the front
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2134899
08/17/16 02:31 AM
08/17/16 02:31 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Its only for the 67-72 A-body Dan, that one has been 1.5" from its beginning because of how far forward it mounts.
Mopar to the bone!!!
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2134922
08/17/16 03:47 AM
08/17/16 03:47 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The longer lever arms do reduce the effectiveness compared to the 73-76 A body bars.
Re: Non-Matching Sway Bars, Hotchkis and Addco [Re: Devil] #2165986
10/01/16 05:05 PM
10/01/16 05:05 PM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
Alrighty then. So I'm not making a all out autocross car. Just a good daily driver / new auto archaeology hunting rig. So it should work out well if I can get the matching sway bars.
I'm going to do a post here shortly on my buildup.
