HELP, need valve lash Hughes mec cam 5256
#2121857
07/31/16 12:48 PM
07/31/16 12:48 PM
Posts: 523 Right here
HP2
Right here
Engine is warm but now I can't find the papers with correct gap... Cam is a Hug HTL5256BS
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
Re: HELP, need valve lash Hughes mec cam 5256
[Re: HP2]
#2121927
07/31/16 02:20 PM
07/31/16 02:20 PM
Posts: 760 Canada
CTD5.9
Canada
small block or big block? either way they don't have that cam on their website anymore. The one smaller STL5054BS3 is .010/0.012 and the STL5460BS3 is 0.018/0.020. They don't even have it on their old page http://www.hughesengines.com/TechArticles/9oldercamshaftprofilesbigblocksolidhevseries.php but the recommendation on those ones are Valve Lash Settings: Intake .018" - .020" Exhaust .020" - .022" personally I would do them 0.018/0.020 and call it a day but there is potential that's not quite right.
[Re: HP2]
#2123154
08/02/16 03:09 AM
08/02/16 03:09 AM
HP2
Right here
Thanks for your reply. 440", now with SidewInders. As you say the link is broken on their site. I took a shot and set them all .020, seems like it will work! Will test it today on 1/8
[Re: HP2]
#2124163
08/03/16 05:18 PM
08/03/16 05:18 PM
fast68plymouth
So. Burlington, Vt.
Since the cam is pretty small for your combo, I'd set them at .010 cold, and tune from there.
