Page 2 of 7 1 2 3 4 5 6 7
Re: Organosol "The Bulletin" January 15, 1969 [Re: RoadRunnerJD] #21234
01/26/06 05:20 PM
01/26/06 05:20 PM
Just tried ordering the Organisol from Totally Auto and the lady said that 1968-1970 Chargers were a smooth finish and was just a semi flat black paint. Kinda contradicts what the TSB attachement says.
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21235
03/24/07 12:29 AM
03/24/07 12:29 AM
CH
P
plyrr69 Offline
plyrr69  Offline
P
CH
I just finished spraying an A12 hood with
9355 lacquer which I bought and had mixed at my
local PPg supplier and i mesed it up the first
time by spraying it on too heavy and wet cause of hearing all the complaints of hoods being too gritty.i had too sand it all down cause the texture all went to the bottom.This time I mixed
it 150% with slow lacquer thinner and sprayed it on Medium wet and it went on perfect.It is
supposed to have texture,this hood feels like
220-320 grit sandpaper and i think that is what it is supposed to look like.Use a gravity feed
gun to spray it with so you can spray it with
lower air pressure.Siphon feed guns require about
45 psi and i think that is where the dry or zebra
stripes come into play.I used a Sata HVLP with
1.4 tip and it sprayed even and no stripes or
dry spray.it looks good in my book.
I am getting to paint my K2 A12, do you have a pic of your hood? Because my hood is too shiny!
thx
David
___________________________ .......plymouth tells it like it is...!
Re: Organosol "The Bulletin" January 15, 1969 [Re: plyrr69] #21236
03/27/07 03:32 AM
03/27/07 03:32 AM
Franklinville,NJ
JeffsCustomPaint Offline
Franklinville,NJ
yes I have several pics of the hood
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21237
03/27/07 03:37 AM
03/27/07 03:37 AM
Franklinville,NJ
Franklinville,NJ
another
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21238
03/27/07 03:44 AM
03/27/07 03:44 AM
Franklinville,NJ
Franklinville,NJ
here's another but I have more
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21239
03/27/07 04:30 AM
03/27/07 04:30 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Thanks for posting those Jeff. Do you have any shots close up that might show the texure you achieved using this technique?
I can't afford this. mark
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21240
03/27/07 06:51 AM
03/27/07 06:51 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
NOTE: Engine exterior area of hood to be painted with
2183385 Exterior Air Dry Organsol Paint AX5DX8 Black,
prior to installing hood retaining parts. 1-16-69
Painters out there, does this make any sense? Are the paint codes still relevant?
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: a12superbee] #21241
03/27/07 08:38 AM
03/27/07 08:38 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Same here... because it doesn't look like it has any texture at all in your pictures.
Re: Organosol "The Bulletin" January 15, 1969 [Re: BradH] #21242
03/27/07 08:50 AM
03/27/07 08:50 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Jeffs hood looks like the hood of my R4 Bee I got in 74.
Getting old just means you were smarter than some and luckier than others.
Re: Organosol "The Bulletin" January 15, 1969 [Re: dannysbee] #21243
10/16/07 07:13 PM
10/16/07 07:13 PM
Franklinville,NJ
Franklinville,NJ
hey all sorry been gone from the boards for awhile
not sure if i have any close ups that show the texture. That hood was done over a year ago
I haven't seen the car since I finished working on it.One of these days i need to go get some pics of the car in all it's glory with it finished in a nice scenic backdrop.
I'll have to search my pics to see what i have
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21244
10/17/07 10:37 AM
10/17/07 10:37 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
So what's the conclusion on what to use
on AAR's, T/A's and cuda tail panels ?
Thanks, Logan426
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21245
10/18/07 12:03 PM
10/18/07 12:03 PM
cataclysm80 Offline
cataclysm80  Offline
Tav
Re: Organosol "The Bulletin" January 15, 1969 [Re: cataclysm80] #21246
10/18/07 02:07 PM
10/18/07 02:07 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Tav
Don't wait for me, I originally posted this December 17, 2005 and Jeff dug it up and it to the top. If I were painting an AAR, T/A hood or an A12 Lift-Off-Hood I would seriously look into this "Note";
MikeR
I'm with you on this
BTW Tav, you seem to be waiting for something (from me?? ) in another few re-posts of mine, anything I can do to help let me know because I'm a little
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21247
10/18/07 02:25 PM
10/18/07 02:25 PM
VA
RapidRunner Offline
RapidRunner  Offline
VA
Any were might that NOTE have come from
MikeE
Who knows? The Shadow Knows! But he ain't on this fraking forum! "This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!" -------------------------------
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21248
10/18/07 08:07 PM
10/18/07 08:07 PM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Not sure if this helps but that AX5DX8 black seems to be an actual factory< in house> paint code. I know from working in the chrysler facility I was stationed at all of our quart cans and gallon cans of paint material all had an extra label secured over the original along with extra paint codes on it. This was to reduce the amount of lunch pail theft as you weren't really sure of what you were taking without peeling the outside label off. Just a thought. My paint supplier told me that the only codes for organisol in his books from 1969 were the 9355 which probably is correct for doing the rocker blackout as well as the tail panels for chargers etc. as listed on that TSB. He did give me another product which I had forgotten about which is called High Performance Black DDL 9381. That number has been changed to DDL 9423. I remember painting the glass hood for my dads T/A Challenger with this years ago and it seems like it might be the right stuff. I am going over to his shop and look around and see if I can find that gallon can. Has anyone tried using the DDL9423?
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21249
10/18/07 08:15 PM
10/18/07 08:15 PM
Franklinville,NJ
Franklinville,NJ
MikeR
Mike i read that this thread was mentioned in Lon's thread about his hood and i seen that some people wanted to see pics of the hood i did upclose and they were after i last posted so i responded to that not to really dig it out and bump it but it is a good thread and people
still need to do the organosol but sometime can't find info on it. It's a good thread to save
Re: Organosol "The Bulletin" January 15, 1969 [Re: JeffsCustomPaint] #21250
10/18/07 08:46 PM
10/18/07 08:46 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Jeff, I'm happy that it came back up, I was just kind of responding to the from Tav, like someone was waiting for the other shoe to drop from me
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: QuickSilver] #21251
10/18/07 09:01 PM
10/18/07 09:01 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Joey, for sure that is the factory paint code (AX5DX8) for the A12 hoods (and maybe the AAR/T/A too?) and then the 9407 was from memory by a good friend and excellent source and he may be off on the last two numbers because he used the "94" several times until he settled for 9407. The DDL9423 may be the "missing link" for the closest match to the hood paint
MikeR
Re: Organosol "The Bulletin" January 15, 1969 [Re: A12] #21252
10/18/07 09:09 PM
10/18/07 09:09 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
None of the Organosols today are anywhere near the originals, both the metallic and suede used originally is no longer available.
9381 is a Ford color that was used on the shaker hoods and scoops.
Amazing how an unchallenged lie can become the absolute truth.
Re: Organosol "The Bulletin" January 15, 1969 [Re: beepbeep] #21253
10/18/07 09:29 PM
10/18/07 09:29 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
August 30, 2007
Authentic Restoration Products from
Roger Gibson
Auto Restoration
E-mail: sixpackfrank@aol.com
Web: www.rogergibsonautorestoration.com
ORGP/ORGQ Organosol - authentic black textured finish for hoods, tail panels…………Qt $95.00
***ONCE AGAIN AVAILABLE*** .................................Pint $50.00
I'm pretty sure this is the latest version and not from the original supply that was supposedly around for a while. Anyone talk to Frank lately about it?
MikeR
