Page 1 of 3 1 2 3
Wow... Time for 5/8“ wheel studs?! #2121136
07/30/16 09:24 AM
07/30/16 09:24 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Went to take off my wheels yesterday to mount up some new tires. Couldn't believe my eyes!
Checked all of the lugs and they were all at least 100 ft/lbs to remove, so they weren't loose!
These where strange screw in studs running with a steet wheel. Drag radials, Trans brake, 3740lbs, 1.38 best 60ft.
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121138
07/30/16 09:30 AM
07/30/16 09:30 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Good catch 8-)
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121145
07/30/16 09:51 AM
07/30/16 09:51 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
yes...good catch!!
could have been a big OOPS...
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121148
07/30/16 10:06 AM
07/30/16 10:06 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Is that an 8.8 rear?
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121151
07/30/16 10:11 AM
07/30/16 10:11 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
And/or put that thing on a diet! haha
Good catch!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121158
07/30/16 10:18 AM
07/30/16 10:18 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Check the housing for straightness, good chance it's bent also.
Have a great day
Iowan
"obsolete is neat"
Re: Wow... Time for 5/8“ wheel studs?! [Re: Iowan] #2121161
07/30/16 10:25 AM
07/30/16 10:25 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Do i see the pic right? It looks like the holes in the flanges are bigger than the studs going through them. If so, that wouldnt provide the stud with any side support.
Edit...i see its a disc brake rotor on there.
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121165
07/30/16 10:33 AM
07/30/16 10:33 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I was shearing 1/2" studs in my "Cuda before I switched over to 5/8" drive studs. Never hurt a wheel again. It is a little work, though. Axles have to be drilled and tapped. Holes in brake rotors will have to be opened up. And it will be a pretty snug fit with the wheels, too. It will be a straight shot in, so you will have to be able to maneuver the wheel around in the wheel well for that.
[image][/image]
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121187
07/30/16 11:26 AM
07/30/16 11:26 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Where are you gonna find steel wheels for 5/8 studs? smile
I remember Monte saying drag radial cars need to be built like a promod in the rear.
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121195
07/30/16 11:49 AM
07/30/16 11:49 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
James... good eye, but it's actually explorer disc brakes on a Dana 60.
I can't imagine that the D60 housing is bent, but I'll look for sure.
What's scary is the reason I took the wheels off is to put the new PRO 275's on the car so I can get it to leave HARDER...(gulp!)
Might be time for some aluminum wheels, and a sneaky paint job to keep that steel wheel look.
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121211
07/30/16 12:06 PM
07/30/16 12:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I need to upgrade also.
Re: Wow... Time for 5/8“ wheel studs?! [Re: TRENDZ] #2121218
07/30/16 12:14 PM
07/30/16 12:14 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Should be able to drill those and rechamfer the lug seat. Those wheels dont look like they have the raised chamfered area that disappears (like a stock rim) when going to a bigger diameter hole. I would make sure the locations were good though.
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121226
07/30/16 12:25 PM
07/30/16 12:25 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Maybe it's just the photo but the center hole in your wheel appeared to be larger than the register on the axle. If this is the case I can see how this would be hard on the studs.
Good luck with it all,
Bill
Re: Wow... Time for 5/8“ wheel studs?! [Re: 340Cuda] #2121233
07/30/16 12:34 PM
07/30/16 12:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Happens a lot on steel wheels... the surface area
at the base of the stud isnt big enough.. with all
the torque they will move.. and pounds on the edges
of the base.. once its large enough it can do anything..
but see where the studs are cut down .. thats at the base
area
wave
Re: Wow... Time for 5/8“ wheel studs?! [Re: 340Cuda] #2121259
07/30/16 01:07 PM
07/30/16 01:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Bill
I agree, that register hole in the wheel doesn't match the axel register. That, didn't help at all. Probably the main cause. Second all the power at the hit, that your putting down.
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121289
07/30/16 02:03 PM
07/30/16 02:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya man, you be needin the big dawgs now w/that beast of yours..........
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121290
07/30/16 02:06 PM
07/30/16 02:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No...........the problem is drag radials. They are unforgiving and break EVERYTHING. And I would also bet the housing is bent from the spring perches out.
The issue with steel wheels and ANY size stud in something with power, is the way the wheel mounts. When aftermarket parts are involved, the wheel no longer registers on the axle. The hole in the wheel is bigger than stud and your sole means of support is the cone on the nut. Add drag radials and I am surprised it hasn't already broke the studs. So even if you do go 5/8 studs, you are going to have to come up with another way to clamp a steel wheel, if that is what you are going to run. The wheel MUST fit the unthreaded shank on the stud, as that is what supports the wheel
Re: Wow... Time for 5/8“ wheel studs?! [Re: Monte_Smith] #2121294
07/30/16 02:10 PM
07/30/16 02:10 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Mine snapped an ear off a Spicer 7290 u-joint 2 weeks ago running ET Street Pro's. I was surprised it happened at my power level! Of course it was trashing the Auburn sure-grip as well but I expected that.
'63 Dodge 330
11.19 @ 121 mph
Re: Wow... Time for 5/8“ wheel studs?! [Re: Monte_Smith] #2121334
07/30/16 03:04 PM
07/30/16 03:04 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
What Monte said but I will add that the vee shape hole in the steel wheel is like a cleaver to the stud. It may be possible to get straight shank studs and open up the holes in the wheels to the straight size diameter, or maybe some hat inserts like Lamb sells for the front wheels. There is a yellow TT Nova here that sheared off the studs launching on a well prepped track (Raidalfest at Huntsville) two events in a row. He put new studs on this year after shearing them off last year, and the results were the same except this year he went into the wall. Steel wheels on threaded studs + traction + power = trouble.
Yeah, you dodged a bullet. Go buy a lotto ticket.
Re: Wow... Time for 5/8“ wheel studs?! [Re: dizuster] #2121370
07/30/16 03:57 PM
07/30/16 03:57 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
The narrow section width of the steel wheel is putting a huge load on the studs with the power you are putting out. A longer stud and thicker wheel should spread the load out. I saw a guy with a sleeper car like yours that had a pair of Holeshot wheels painted body color and he had the hubcap fastened on there somehow.
Page 1 of 3 1 2 3
