Re: Want to install 71 grill in my 74 cuda. What parts needed?
[Re: MoparMike1974]
#2117106
07/25/16 08:39 AM
07/25/16 08:39 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
You will need a 71 grill and 4 headlights. ☺ Welcome to Moparts Mike. Hopefully someone with some E body knowlegde can help you.
I vote for doing the sidemarkers and tail lights panel too.
[Re: MoparMike1974]
#2117935
07/26/16 09:24 AM
07/26/16 09:24 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
you would probably need a older 70-71 front bumper with brackets. the 74 had those big energy absorber brackets and fillers for the gaps they cause.
perception is 90% of reality
[Re: MoparMike1974]
#2119610
07/28/16 03:09 AM
07/28/16 03:09 AM
Posts: 294 Maryland
MoparMike1974
Maryland
Im swapping out the 74 bumper brackets for some 72's to eliminate the bulky bumper look. I think I will go with some new fenders. I thought the 71-74 header panels were the same? What is different about the hood latch? The wiring is no problem, thats the easy part. So here is the parts list of things I definitely need to buy -repro grill -head lamp bracket -grill mtg brackets -side marker light set -valance
I would like a second opinion on the hood latch and header panel.
As far as the front valance is concerned, I could use the 74 as it has the turn signals in it too. Hmm, I wonder how that would look.
[Re: MoparMike1974]
#2119668
07/28/16 09:57 AM
07/28/16 09:57 AM
Mr T2U
it's been a few years since I worked on a 71 cuda so my memory might be wrong. the top of the header panel, between the fenders, is the same. the lower bracing where the grill mounts to is different on the 71. on the hood latch. the secondary hood release, part you push that goes thru the grill, is different between the years.
[Re: MoparMike1974]
#2120965
07/29/16 10:37 PM
07/29/16 10:37 PM
Posts: 6,007 Salem
Grizzly
Moparts Proctologist
Salem
So what is the general opinion on running the 71 grill but keeping the 72-74 valance? I was pricing everything out and those 71 parking lights are absolutely ridiculously priced. Im not spending $500 on a pair of running lights. You see things my way. I have a '74 and I've given this some thought too (either '70 or '71 style direction): -The signal lights on the '74's are an eyesore, I'll throw mine away. I was thinking about doing some of those new LED style lights and setting them behind the grill for signal lights. -The side markers are also an eyesore, they're going in the garbage as well and I was thinking about small LEDs there too and filling the rest of the hole.
Mo' Farts
Moderated by "tbagger".
[Re: MoparMike1974]
#2121089
07/30/16 02:54 AM
07/30/16 02:54 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
So what is the general opinion on running the 71 grill but keeping the 72-74 valance? I was pricing everything out and those 71 parking lights are absolutely ridiculously priced. Im not spending $500 on a pair of running lights. Welcome to the world of 71 cudas
[Re: MoparMike1974]
#2124737
08/04/16 12:04 PM
08/04/16 12:04 PM
Posts: 12,235 Looking for a way out of Middl...
IMGTX
I have a couple questions. Do I have to modify my 74 fenders to use the 74 grill? If so, are the pieces available? Second, are the headlight buckets from a 72-4 challenger the same as 71 cuda? Im sure I have a set of them. The 71 inside the fenders is different. The 4 headlight fenders (71) have a smaller recess than the 2 headlight cars (70 & 72-74). You may be able to work the brackets in but how much work I am not sure. Here are the parts for conversion. I'm sure other companies make them too but these were easy to find. http://beaparts.com/list_items.aspx?body=E&cat=E&subcat=37I do not know if the brackets that hold headlamp buckets on a challenger will fit but the buckets that the bulbs (lamps) set into and the trim rings that hold the bulbs into the buckets will fit from any 4 headlight mopar of that era. There are differences in high low and left right.
[Re: MoparMike1974]
#2124744
08/04/16 12:15 PM
08/04/16 12:15 PM
Posts: 1,687 Boston, MA
crocha617
Boston, MA
So what is the general opinion on running the 71 grill but keeping the 72-74 valance? I was pricing everything out and those 71 parking lights are absolutely ridiculously priced. Im not spending $500 on a pair of running lights. I've got a couple of extra left side parking lights here if you can find a right side...
[Re: MoparMike1974]
#2124746
08/04/16 12:17 PM
08/04/16 12:17 PM
crocha617
Boston, MA
So what is the general opinion on running the 71 grill but keeping the 72-74 valance? I was pricing everything out and those 71 parking lights are absolutely ridiculously priced. Im not spending $500 on a pair of running lights. I have a few extra left side parking lights if you can find a right side I'll sell you one cheap.
