2 Speed Wiper Resistor Value? #211722
02/02/09 10:58 AM
02/02/09 10:58 AM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
How many ohms should the resistor mounted on my 2 speed wiper motor have? I'm assuming it's for low speed operation. I measured mine after I cleaned it up and got .5 ohms which seems low but I have nothing to compare it to. Thanks for your help!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: 2 Speed Wiper Resistor Value? [Re: itali83] #211723
02/02/09 12:47 PM
02/02/09 12:47 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
they are still available at some on line dealers. Buymopar.com was one of them but they are not on line anymore, dunno if still on bussiness.
Tried to measured mine with the tester I have in hands right now, and doesn't read decimals, got 1 ohms, but I guess because isn't able to read less. The other tester is not handly right now, so will be able to check later.
Re: 2 Speed Wiper Resistor Value? [Re: NachoRT74] #211724
02/02/09 01:44 PM
02/02/09 01:44 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
Thanks, maybe mine is fine I just wanted to double check. It seems like the motor itself has resistance because there is a low and high speed even without the resistor depending on which pin I put power to so it probably doesn't need must more from a resistor to make it right. Thanks again.
