Tools to remove snap ring on 727 clutch drum #2116497
07/24/16 05:06 AM
07/24/16 05:06 AM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
Was wondering if anybody here has ever used either of these tools to remove and install the snap ring on the front drum in a 727 trans.
With trans shops charging $15 to $20 just to remove or install, and having to leave it with them 'til the next day, these kind of look like they might work.
I tried C-Clamps and all I ever got was a bent retainer.
Any thoughts or advice would be appreciated.
Thanks, Jeff
tool #1
Tool#2
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116512
07/24/16 09:37 AM
07/24/16 09:37 AM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
Both look like they would work fine.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116529
07/24/16 10:34 AM
07/24/16 10:34 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I made mine with a piece of pipe and use a press. If I going to buy one of the two you posted it would be #1.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116541
07/24/16 11:25 AM
07/24/16 11:25 AM
PA
Scully Offline
Scully  Offline
PA
I notched a piston skirt and put it on the press. Back in the 70s I had 2 people push down with hammer handles while I removed the clip. Those tools would be nice for remote location such as at the track.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116598
07/24/16 12:48 PM
07/24/16 12:48 PM
CA
crackedback Offline
crackedback  Offline
CA
Here is a piece a friend out together to compress that assembly.
http://www.forabodiesonly.com/mopar/attachments/phpqzpimmam-jpg.1714615687/
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116635
07/24/16 01:54 PM
07/24/16 01:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Two equal length sockets in a vice and either a C-clamp or C-Clamp style vice-grips as the "3rd leg". Compress the lower part of the retainer in the vice using the two sockets as spacer between the vice jaw and the retainer. Compress the other side of the retainer with the clamp. Do it all slowly a little at a time. Then remove the snap ring. It's easier with an extra set of hands during reassembly but it can be done by yourself if your patient.
I rebuilt many a trans this way when i didn't have a tool.
Doug
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116653
07/24/16 02:46 PM
07/24/16 02:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's the home made tool I've been using for 40+ years.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116842
07/24/16 09:09 PM
07/24/16 09:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks, Jeff
tool #1
Tool#2
Either one will work, I would go with number 2 . I have the factory miller tool, but I like John K's rendition.
Re: Tools to remove snap ring on 727 clutch drum [Re: JohnRR] #2116858
07/24/16 09:38 PM
07/24/16 09:38 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
wow, you guys that fabricate home made tools are good. up
Shows you can use your noodle, in thinking things out.
I bought this tool, back in the late 1970's when i first started doing transmissions.
Don't remember who made it, or where i purchased it from.
But on the handle it's called a SnaP Press.
Probably went obsolete decades ago.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116860
07/24/16 09:47 PM
07/24/16 09:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I don't remember what I used on my last 727 build, but it was not tool listed here I can say that, except maybe a C clamp. But that was back in 94, so my memory is not there.
Don't be the exception.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116918
07/24/16 11:27 PM
07/24/16 11:27 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
Thanks for the replies.
I like John Kunkel's design as the sides extend along the side of the retainer, possibly eliminating side movement and sliding off.
Hemi71x's snap press looks like it also has the same design.
I think I'll buy the tool #1.
Maybe I can turn up a plug to fit the I.D. of the drum to help locate the screw and eliminate side movement if that becomes a problem.
again, Thanks for the replies and ideas, Jeff
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2116931
07/24/16 11:49 PM
07/24/16 11:49 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I always use c-clamps on all 904s and 727s I build. I've NEVER had a bent retainer
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Tools to remove snap ring on 727 clutch drum [Re: 69L78Nova] #2116960
07/25/16 12:22 AM
07/25/16 12:22 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Was fortunate to acquire the original Miller tool years ago.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117078
07/25/16 05:20 AM
07/25/16 05:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine is sorta like the one "62maxwgn" posted but its a little more open for more room to get at the snap ring. I bought it about 30 years ago from the Snap-On tool man. You dont need a press with it as I just clamp the bottom of the tool in a vise and then run the threaded bolt down to compress the spring. Its all I have used for 30 years. Ron
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117186
07/25/16 11:28 AM
07/25/16 11:28 AM
crlush Offline
crlush  Offline
I just used 3 c clamps and no bent retainer.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117218
07/25/16 12:28 PM
07/25/16 12:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was doing a powerglide once and found a PVC coupling that was the right diameter and notched it so I could get to the snap ring and used it in a press , but a big c lamp would have also worked.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117256
07/25/16 01:18 PM
07/25/16 01:18 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
I would go with #1 since the compression screw is on the top and it looks lie you could clamp the bottom in a bench vise to hold it for you
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117308
07/25/16 02:19 PM
07/25/16 02:19 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Easiest/fastest to use is the one like hemi71x shows - I bought one like that, along with a foot operated one many years ago when a local shop closed. Also got a small box of assorted ones like the O/P posted as tool#1.
Google T-0158-SP and you will find several companies that sell the one that hemi71x shows, starting at about $135 on e-bay. Google T-0171 for the foot press I mentioned - they seem to start about $400.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Tools to remove snap ring on 727 clutch drum [Re: 62maxwgn] #2117378
07/25/16 03:43 PM
07/25/16 03:43 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Got one of those off ebay 12 yrs ago...for 50 bucks.
Tony
70 AARCuda Vitamin C
Re: Tools to remove snap ring on 727 clutch drum [Re: 62maxwgn] #2117382
07/25/16 03:47 PM
07/25/16 03:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have that tool, I bought it directly from Miller around 2002, it is also used to press the rear sprag outer race into the case.
