Beginning to regret using March Pulley system!!!!!!!!! #2116362
07/23/16 10:23 PM
07/23/16 10:23 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
I've had a GM style one wire alternator on my car for a few years. The car is a 70 Charger with stroker big block. Frankly it does not get out much any more. I have a March single serpentine system with the Tuff Stuff alternator. All wiring was new but it does have a stock style ammeter in the cluster that was redone by performance car graphics. I originally had an issue with the charging terminal being loose inside the case making me unable to get a tight connection on the charging wire. All is tight now and I had alternator rebuilt locally as well. Problem is it still does not look to be charging....the ammeter shows a moderate discharge and when tested with a multimeter at the battery it reads only 12.06 and no difference running or off. Originally this would show the charging. Ive read a few horror stories and it looks like I need to bypass the ammeter and just connect the wires together on the same terminal and then just run wire to straight to the battery or the starter relay. Any other ideas here?
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116365
07/23/16 10:35 PM
07/23/16 10:35 PM
first we need to solve the no charge prob then see if you want to bypass the ammeter or not. EDIT I ain't up on 1 wire alts but I think if the main wire to it is hot then if it dont charge then it has to be the alt itself (I would think) but wait for others to chime in that know that system
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: RapidRobert] #2116585
07/24/16 12:35 PM
07/24/16 12:35 PM
Alberta
rustbuckett68 Offline
Alberta
Seem to remember that the 1 wire units needed to be revved up to excite the internals before they could charge.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116620
07/24/16 01:29 PM
07/24/16 01:29 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I thought I read somewhere they needed at least a 1,000 rpms to charge.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116636
07/24/16 01:54 PM
07/24/16 01:54 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've found that the copper windings, or lack of, had more of a low rpm charge effect than anything. too larger a pulley will have an effect too.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116644
07/24/16 02:26 PM
07/24/16 02:26 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
So...once I plugged my electric fans in, it began to charge. I think I saw somewhere that once it was below 11 volts it would charge...makes no sense to me. Maybe its just smarter than I am and only charges when it sees a draw. Nevertheless I ran it for a good half hour and it continued to show positive amperage.
Now on to a new issue which has been somewhat recurring....The march system came with a billet ps pump and It has always seemed to me like it gets way too hot and boils out the fluid. After 30 minutes of run time in the driveway, I have a good size puddle and the fluid looks mighty dark.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116696
07/24/16 04:03 PM
07/24/16 04:03 PM
md
mopars4ever Offline
mopars4ever  Offline
md
What size pulley is on the the p/s pump?
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: mopars4ever] #2116741
07/24/16 06:00 PM
07/24/16 06:00 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Looks to be about 5 3/4". I may have a gear box issue. It looks like it is coming from the connection/valve on the top of the gear box. Ironically even with so much fluid on the ground, the pumps full to the cap.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116747
07/24/16 06:14 PM
07/24/16 06:14 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
After sitting a couple hours the puddle is larger and now the pump looks empty.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116775
07/24/16 07:29 PM
07/24/16 07:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Maybe I missed something, but what part does "march" play in this matter?
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116783
07/24/16 07:52 PM
07/24/16 07:52 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I think I had the 2 wires swapped on back of my gage. And it showed a Decharge all the time
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: jcc] #2116911
07/24/16 11:15 PM
07/24/16 11:15 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
The alternator, and power steering pump were all part of the March single serpentine system. A friend of mine also used this system on a small block Cuda. Both of us have had issues with the power steering system boiling fluid out and leaking significantly.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2116915
07/24/16 11:21 PM
07/24/16 11:21 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
you can buy a pulley that goes on a stock power steering pump for that system.
perception is 90% of reality
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2117011
07/25/16 01:16 AM
07/25/16 01:16 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The power steering pulley looks to small and you might want to add a cooler.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2117071
07/25/16 04:39 AM
07/25/16 04:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The power steering seemed to get hot on my Billet Specialities Tru-Track also. It has a remote resivor and I added a cooler.
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2117149
07/25/16 10:35 AM
07/25/16 10:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That PS pulley looks like a 1:1 pulley to crankshaft ratio? Should be bigger pulley on the PS to slow it down. I bet they do a smaller pulley because it looks way better than some huge PS pulley. Perhaps a cooler is in order?
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2117178
07/25/16 11:22 AM
07/25/16 11:22 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
our serpentine belt kits are design off the factory parts and made to work like the factory put it there. sure its nice that things are flash but if they don't work, what's the point?
we can make a custom pulley to work with your setup if that's the way you want to go.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Tuff Stuff 1 wire Alt not charging?????? [Re: scoutsr2] #2117270
07/25/16 01:33 PM
07/25/16 01:33 PM
P
Paul_Fancsali Offline
P
DRive pulley is way too big compared to what Ma had on that car 12.06 is not charging period
Re: Beginning to regret using March Pulley system!!!!!!!!! [Re: scoutsr2] #2117564
07/25/16 08:15 PM
07/25/16 08:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What does March's Pulley System have to do with your charging problems? Seems wrong to slam them for something they have no control over. If their pulley ratios are off, that's another story.
Re: Beginning to regret using March Pulley system!!!!!!!!! [Re: scoutsr2] #2117628
07/25/16 09:50 PM
07/25/16 09:50 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
Why a 1 wire alternator?
I've done extensive research on alternators a while back and everything i have read says for an automobile with factory wiring, never use a 1 wire alternator. if the designers of the wiring system felt that a 1 wire alternator was sufficient, they would have put it in cause auto manufactures want to save every penny they can. 1 wire alternators are best suited for tractors and other farm equipment that don't have the taxing accessories that a car has.
now i know someone's gonna say "I've been using a 1 wire alternator for years with no problems" and that might be ok for them. but I'd loose the 1 wire and put on you car what was suppose to be on there. then see if you have charging issues.
