How do I properly paint parts after bead blasting?
#2116032
07/23/16 10:59 AM
07/23/16 10:59 AM
Posts: 128 pa
mikeporp
pa
I am using a bead Blaster we have at work to blast some engine and other brackets and seat tracks. What should they be cleaned and wiped down with before priming what sort of primer and paint should be used? I am also going to be blasting my original exhaust manifolds what would be the process for this and type of primer and paint for them? The car is a 70 Challenger convertible. Thanks, Mike.
1970 challenger convertible
Re: How do I properly paint parts after bead blasting?
[Re: mikeporp]
#2116041
07/23/16 11:22 AM
07/23/16 11:22 AM
Posts: 18,165 Mass
DAYCLONA
Mass
I am using a bead Blaster we have at work to blast some engine and other brackets and seat tracks. What should they be cleaned and wiped down with before priming what sort of primer and paint should be used? I am also going to be blasting my original exhaust manifolds what would be the process for this and type of primer and paint for them? The car is a 70 Challenger convertible. Thanks, Mike. If you know the glass beader is free from grease/oil contaminants , just blow the parts off with compressed air, if not acetone the parts after blasting, generally I initially coat everything with an etch primer like Dupont Vari-Prime or an epoxy sealer, prior to priming or painting the part in it's finished coating as far as the manifolds, blast, blow, and coat with the hi temp finish desired...
[Re: DAYCLONA]
#2116060
07/23/16 11:46 AM
07/23/16 11:46 AM
Posts: 12,801 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Do you now anybody in the body shop business? "Wax and grease remover" is the best wipe down product to use prior to painting. It would only take a few ounces to wipe down your parts, so any body shop would likely give you that tiny amount. But any good solvent like acetone or tolulene or MEK will do okay.
The etching primer is a very good idea. And if you want a good stable final finish, it is best to use paint that requires a hardener mixed with it. Most call it single stage, the kind that you mix 2 or 3 parts together and spray with a gun. Aerosol spray paint looks good, but is not nearly as durable.
Or you can consider powder coat. It is not very expensive for already prepped parts like yours and you can get most any level of gloss or flatness that you are trying to achieve. Although, I doubt that it is viable for your manifolds.
Master, again and still
[Re: mikeporp]
#2116064
07/23/16 11:53 AM
07/23/16 11:53 AM
Posts: 128 pa
mikeporp
pa
Thanks so much for the tips as far as the manifolds, does anyone know how to get the best original look to them. Thanks, Mike.
[Re: mikeporp]
#2116160
07/23/16 03:14 PM
07/23/16 03:14 PM
Posts: 26,470 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Glass beading occasionally leaves the part with a static charge (static cling) that only water will break. Wash the part in soap and water, rinse in clean water then blow dry.
[Re: mikeporp]
#2116187
07/23/16 04:06 PM
07/23/16 04:06 PM
Posts: 128 pa
mikeporp
pa
OK...thanks again for all the great tips I haven't blasted the manifolds yet but I'm guessing I will have to.
[Re: mikeporp]
#2116195
07/23/16 04:34 PM
07/23/16 04:34 PM
Posts: 9,031 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
as far as the manifolds, does anyone know how to get the best original look to them. Sure, spray with water and let them rust. Seriously, how long did manifolds stay "bare iron"? They had usually rusted by the time the car was driven off the lot!
[Re: Stanton]
#2116250
07/23/16 06:19 PM
07/23/16 06:19 PM
Posts: 16,186 Mesa, Arizona
dart4forte
Mesa, Arizona
Wax and grease then blow dry. Tac cloth and spray a base primer
Abe Lincoln
[Re: John_Kunkel]
#2116412
07/24/16 12:05 AM
07/24/16 12:05 AM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Glass beading occasionally leaves the part with a static charge (static cling) that only water will break. Wash the part in soap and water, rinse in clean water then blow dry. Wash with Dawn, rinse, dry with compressed air and paint.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: mikeporp]
#2116546
07/24/16 11:29 AM
07/24/16 11:29 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Glass beading occasionally leaves the part with a static charge (static cling) that only water will break. Wash the part in soap and water, rinse in clean water then blow dry. Its not the water that discharges the static, its the "grounding".
[Re: mikeporp]
#2116625
07/24/16 01:35 PM
07/24/16 01:35 PM
Posts: 128 pa
mikeporp
pa
I also just acquired an original 70 air compressor. I'm going to be putting the a/c components back on. Any tips on what I should do with this to get it looking good. Bead blasting or no?
[Re: Stanton]
#2117118
07/25/16 09:25 AM
07/25/16 09:25 AM
Challenger 1
Cincinnati, Ohio
Y'know, any time I've tacked a blasted part I've ended up with so much lint the part looks like a tennis ball!
Since you have to wipe the wax and grease remover on and off with a rag, I hit the part really well with the blow gun then rub the piece down with a scotchbrite pad then blow again. No tack rag !!
Oh, you want to be wearing latex or similar gloves so you don't contaminate the part.
Paint the parts right away - primer at least. I don't touch the part after blasting and sure as heck don't wipe it down with NOTHING after blasting. Just blow off and paint right after blasting. The part must be cleaned and de greased and de waxed BEFORE blasting. If you don't then you just blasted dirt and grease into the metal pores and wax and grease remover is going to do nothing but make it worst if you try to use it after blasting. Plus all your blasting beads are contaminated too if you blast dirty parts. Only clean stuff gets blasted. Pressure washers are so useful for restoration of anything. Heated pressure washers are even better. The folks who recommend wiping it down after blasting DON'T blast stuff to know any better.
[Re: mikeporp]
#2117148
07/25/16 10:35 AM
07/25/16 10:35 AM
Posts: 128 pa
mikeporp
pa
Thanks very much for all the tips. Although some very conflicting lol, but much appreciated.
[Re: mikeporp]
#2119376
07/27/16 09:27 PM
07/27/16 09:27 PM
Posts: 223 Oreland Pa
clonedshaker+6
Oreland Pa
everyone has there own ways of doing it but as long as its dry has no dirt, rust, ect and you have good products you should be good. I like to use a self etch or epoxy on bare metal
but for exhaust manifold I blasted mine and used the high temp eastwood paint that is like cast iron color and so far it looks good and hasn't come off. my original plan was to do the eastwood paint then put them on the engine, paint them engine color like the factory so it will burn off the orange but look like fresh cast iron instead of rust. but I started to think burned off paint would look like crap no matter how "right" it is,
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present) 03 mustang Mach 1 (daily driver)
11.35 @ 121.5 4 SPEED on F60-15s w/ 6/32 tread
