Re: Mopar ECU for Electronic Distributor how to tell what RPM
[Re: fury4speed]
#2112394
07/18/16 01:07 PM
07/18/16 01:07 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I've never seen one w an RPM rating....but all they are is a transistor switch which I would think could switch faster than the engine ever needed it to....I've never heard of anyone complain that they seem to have an RPM limit.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: fury4speed]
#2112525
07/18/16 03:41 PM
07/18/16 03:41 PM
Posts: 5,440 So Cal
Sinitro
So Cal
Yup... I recall a Mopar Performance bulletin said the Orange box was good up to 6K RPM and the Chrome box up to 8K RPM... I always use a Chrome box, actually have an MSD 6 box with the Chrysler connector (USA made back in the 90s), to me I prefer the Chrome box.. Just my $0.02..
[Re: Sinitro]
#2112661
07/18/16 07:12 PM
07/18/16 07:12 PM
RapidRobert
the MP chrome box gets good reviews here. Might be a bit pricey tho. I would also price one at your parts house. Standard Motor Products parts house ECU's were pretty good but are made overseas now. I've used em on a DD & no issues.
[Re: fury4speed]
#2112892
07/18/16 11:16 PM
07/18/16 11:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Let's see, 4 sparks per rpm assuming V8, remember it sparks once per cylinder every two revolutions.
That would be 24,000 sparks per minute, 4 x 6000.
KHZ means cycles per second, so 24000/60 is 400 hz. The transistor needs to turn on/off 400 times a second, not sure where you got 6000 from.
[Re: Supercuda]
#2112960
07/19/16 12:21 AM
07/19/16 12:21 AM
RapidRobert
Nacho our South American electronic whiz said alot of ECU failures are the main transistor & to replace it with a Motorola "MJ10005". my notes say he said that was for the orange box but not sure if he meant exclusively or if that is what he was working on at the time but the next one I run into that goes out I'm gonna dig out the goo & solder one in & give it a shot. it'd sure be worth it if it fixes it
[Re: RapidRobert]
#2113411
07/19/16 05:08 PM
07/19/16 05:08 PM
dogdays
Supercuda, you forgot that the transistor has to switch off and on in 3 degrees of rotation in order to have 42 degrees closed time or dwell.
R.
[Re: HemiRick]
#2113425
07/19/16 05:44 PM
07/19/16 05:44 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've never seen one w an RPM rating....but all they are is a transistor switch which I would think could switch faster than the engine ever needed it to....I've never heard of anyone complain that they seem to have an RPM limit. The original factory ECU's had published RPM limits that varied from 5200 to 9500 depending on part number/heat sink color. The info is in the old DC racing manual page 471.
[Re: dogdays]
#2113576
07/19/16 09:15 PM
07/19/16 09:15 PM
Supercuda
About to go away
About to go away
up yours
R. None of which affects how many times per second the transistor switches, just how quickly it has to do it. I think you forgot there are 360 degrees in one revolution. Remember each cylinder fires once for every TWO revolutions (720 degrees vice 360 degrees).
[Re: sixpaktoogo]
#2115604
07/22/16 04:04 PM
07/22/16 04:04 PM
Posts: 1,322 Michigan
crlush
I had both the orange box and the chrome box on my 1968 10 second Dart, to see if there was any difference in performance. I shifted my 395 stroker W2 small block at 7,200 rpm. Guess what? No difference in performance, and the orange box worked flawlessly to 7,200 rpm! probably the only difference is the price and the shiny chrome.
