Is a 1978 dodge truck 440 engine harness the same in 1977? #2114437
07/20/16 11:22 PM
07/20/16 11:22 PM
Albuquerque, New Mexico
moparmatt Offline OP
My all original 78 440 power wagon had a harness fire yesterday all I can find is a 77 harness are they the same? Thanks for your help!!
Re: Is a 1978 dodge truck 440 engine harness the same in 1977? [Re: moparmatt] #2114512
07/21/16 01:32 AM
07/21/16 01:32 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I can say that the steering column wiring is different from 1975 to a 1978 model. I'm swapping from a 4 speed to a 727 in my 75 Power wagon. I swapped in a steering column from a 78 and had to use my original 1975 ignition switch wiring.
Re: Is a 1978 dodge truck 440 engine harness the same in 1977? [Re: moparmatt] #2114606
07/21/16 10:18 AM
07/21/16 10:18 AM
It looks to me like 1978 was the start of different direction they were going with truck line so Im thinking wiring , connectors etc changed in 78 and carried on thru 19?? if anyone has any info please post!! Thanks
Re: Is a 1978 dodge truck 440 engine harness the same in 1977? [Re: moparmatt] #2114928
07/21/16 04:54 PM
07/21/16 04:54 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
The "highly acclaimed (?)" Haynes Full sized Dodge pickup 74 thru 93 repair manual lists 5 sets of wiring harness for Dodge trucks.
1) 78 and older
2) 79 & 80
3) 81-84
4) 85-88
5) 89-93
I didn't look at the differences, and the quality of the Haynes book is sometimes questionable, but they made the effort to list 5 different wiring harnesses, so one would expect it is somewhat reality based. Gene
Re: Is a 1978 dodge truck 440 engine harness the same in 1977? [Re: moparmatt] #2115976
07/23/16 04:23 AM
07/23/16 04:23 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Every 77-78 I've had were the same as long as they were for the same engine. That's the only difference I've run into.
