Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#2124754
08/04/16 12:25 PM
08/04/16 12:25 PM
fullmetaljacket
Here's a sneak peak at my ambitions for next Winter blues season. It's a bit difficult in concept with this original part, but after thinking it through for a long time, I have come up with a few ideas using some Rod Shop billet accessories as a base. What got my cogs turning is that these stock window/vent window crank and door latch handles all add up to a few pounds at least.
#2124756
08/04/16 12:26 PM
08/04/16 12:26 PM
fullmetaljacket
#2132772
08/14/16 05:36 PM
08/14/16 05:36 PM
fullmetaljacket
"What's behind door number one?"
Here's an example of the completed door striker with a coat or two of different color and sheen finishes to give the aluminum the illusion of titanium or dirty nickel.
I bumped into some new and old friends at the Nationals this weekend and even got fed as a starving artist. LOL. I asked them to collaborate in performing a human scale test using both their hands to hold the two pieces below. They were awed to say the least. I had to explain that the piece was not a machined or casted piece, but a hand sculpted piece with a Dremel tool as the driving force.
All asked the same question: How many days to make? Answer: Too long in thinking and planning and too anxious in fabrication. LOL.
I get the most satisfaction from people as they cerebrally discover the essence of art.
[Re: Thumperdart]
#2133943
08/15/16 11:13 PM
08/15/16 11:13 PM
Posts: 1,895 Spahn Ranch
RMCHRGR
Spahn Ranch
You need a 3D printer for stuff like this...
'71 Duster '72 Challenger '17 Ram 1500
#2137443
08/20/16 08:14 PM
08/20/16 08:14 PM
fullmetaljacket
Dzuster and friends at Woodward Roadkill event baring witness to the door striker weights between a stock cast steel and a tempered aluminum unit. They were wrapped in shop towels.
#2140853
08/25/16 09:43 PM
08/25/16 09:43 PM
Posts: 1,853 South Bend
John Brown
South Bend
Lee, did you just Dremel those bad boys dry or did you use a lubricant on the tool? I used to use Blaster when I was porting aluminum heads to keep the bit from clogging, but no doubt that cast aluminum was a lot softer than 7075.
