stubborn overtightened lug nut? #2113892
07/20/16 11:09 AM
07/20/16 11:09 AM
fullmetaljacket Offline OP
Other than going to the Dremel tool or buzz saw, what successful remedies have you guys applied to removing an over tightened wheel lug nut?
This is not a rusted lug, but an overly torqued lug.
I'll never again let a flat fix guy tighten the wheel lugs with an impact gun.
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2113896
07/20/16 11:13 AM
07/20/16 11:13 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Get out the torch and heat them up a bit.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: stubborn overtightened lug nut? [Re: 19swinger70] #2113907
07/20/16 11:27 AM
07/20/16 11:27 AM
I always thought that heat was introduced only on a rusted lug. Is it the heat expanding the metal to loosen it?
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2113915
07/20/16 11:37 AM
07/20/16 11:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
impact socket , breaker bar and a pipe on the breaker bar ... yes it's that easy .
Or go back to the donkey that put them on too tight and have him loosen it and then you tighten it ???
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2113923
07/20/16 11:41 AM
07/20/16 11:41 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Use a good impact to remove it. Not a average impact wrench.
A hand held propane or better yet map gas torch will provide enough heat to get it off with regular tools.
FWIW for 25 years I used regular old 1/2' impacts at home and at work and ran into plenty of cases where it was not enough. I would drag out my heavy 3/4" impact and hopefully had a small enough socket to do the job.
Then one of my 1/2" impacts broke,the trigger broke. Cracked off when I threw another tool into the tool box on top of it. I showed it to my Snap On guy and he said it was so old it was not worth fixing and they would not have parts for it? He was right it was old. He talked me into buying a new lightweight composite impact from him.
Wow that thing is powerful and does a much better job of getting things loose and is much lighter to drag around. Well worth the 450 bucks it cost. Should have had one years ago.
It was a Xmas special and I got a pistol gun case and a long 3/8" ratchet for replacing belts on cars and trucks that came with the impact wrench. I work on big trucks at work so I need a powerful impact, so nice to have the right tool for the job and didn't realize how weak my 1/2" impacts were.
Re: stubborn overtightened lug nut? [Re: Challenger 1] #2113949
07/20/16 12:13 PM
07/20/16 12:13 PM
Tried a long breaker bar and socket. Large lug wrench, even a pair of vise grips after the socket started to strip the lug. I'm in Detroit now so I can not go back to the Bozo in Brooklyn.
I'll try and go to a local flat fix here and see what they can do. If not, I'll take to the torch and then the Dremel as last resort.
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2113973
07/20/16 12:37 PM
07/20/16 12:37 PM
P
Paul_Fancsali Offline
P
No 3/4 or 1 inch I use a 1500+ lb Ingersoll rand it never fails or breaks it
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2113978
07/20/16 12:41 PM
07/20/16 12:41 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Have you tried a six-point impact socket with a breaker bar?
Its a bit too late in this case, but I always use anti-sieze on all my Mopar lugs and tighten them to 65 ft lbs with a torque wrench to avoid warping the flange.
Re: stubborn overtightened lug nut? [Re: jbc426] #2113982
07/20/16 12:50 PM
07/20/16 12:50 PM
you might go ahead with the dremel, as you know it will take some time (& save you a trip as you were considering a trip to another shop) but you'll know there will no further damage
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2113988
07/20/16 12:59 PM
07/20/16 12:59 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Try pounding a six point metric socket on the lug. It may fit more snugly than an SAE socket. Or vice versa...
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2114035
07/20/16 01:54 PM
07/20/16 01:54 PM
Cincinnati, Ohio
Cincinnati, Ohio
Don't be afraid of using a little heat, it'll do the job.
A tire store will have a tool like this one that will remove damaged lug nuts or locking lug nuts.
Snap on
This one of the most affordable and useful tools in my shop. I use one at work and at home. It is easier than using the acetylene torch at work and usually puts out enough heat for light duty jobs like lug nuts. Real handy for lighting fireworks and bottle rockets too. ozbbq
Good luck, between hammering on a old socket on it and some heat it should come off with a breaker bar. Have never owned a dremmel tool, too light duty for me. down
Re: stubborn overtightened lug nut? [Re: Cuda340] #2114041
07/20/16 02:01 PM
07/20/16 02:01 PM
Six point metric socket worked. Thank you guys.
Now I just have to pound out the lug wedged in the socket with a steel rod. At the very least, it cost me a metric socket and not a lug stud and time.
Goes to show, that even though we use SAE sockets, the metrics come in on their own and rise to the occasion.
Thank you once again.
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2114046
07/20/16 02:06 PM
07/20/16 02:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Dad had the same problem on his Sebring. Problem is the wheels are chrome "clad"...as in plastic. Can't use a torch on that one. We ended up having to drill out the stud.
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2114055
07/20/16 02:23 PM
07/20/16 02:23 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Are you sure it's not a left hand thread?
Re: stubborn overtightened lug nut? [Re: burdar] #2114069
07/20/16 02:47 PM
07/20/16 02:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
Our durango lug nuts are the same way, 21 MM or something like that? I use a 6 point socket and a impact to take them off and a torque wrench to tighten them.
Re: stubborn overtightened lug nut? [Re: bobby66] #2114093
07/20/16 03:08 PM
07/20/16 03:08 PM
No left hand after a certain year. This is on my 83' Dodge Diplomat police package.
Torque wrench or star wrench from here on.
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2114140
07/20/16 04:06 PM
07/20/16 04:06 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Re: stubborn overtightened lug nut? [Re: fullmetaljacket] #2114149
07/20/16 04:18 PM
07/20/16 04:18 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Always use a 6 point socket on the tight ones or it will round off. Also support the breaker bar at the end of the socket so when you push down you keep the socket straight on the lug nut..
What kind of wheel aluminum or steel? Will the heat hurt the wheel? Can you get at the lug with a die grinder(last resort).
Re: stubborn overtightened lug nut? [Re: NANKET] #2114194
07/20/16 04:59 PM
07/20/16 04:59 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Just went through this with my Durango. Wife was driving it, had a flat, and called AAA. Kid came out and put on the spare and used I-don't-know-what to put the spare on. I fixed the tire and went to put it back on. 2 of the lug nuts were rounded off. Used a metric socket and got one off. The other was so tight I broke the end of it off with a stripped-nut removing socket. mad Wound up drilling the nut with a small bit and popping it in 2 with a chisel. Saved the stud. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: stubborn overtightened lug nut? [Re: NANKET] #2114219
07/20/16 05:19 PM
07/20/16 05:19 PM
Wheel is steel and I did just what you suggested with the breaker bar. I got it loosened finally this morning.
Just glad I wasn't caught out there with a flat and no way of removing the wheel.
