Re: 74 Dash fit in 90 cab
[Re: lunacy]
#2113886
07/20/16 11:04 AM
07/20/16 11:04 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
wipers are in the same place. I put a bird bath hood and cowl from a '77 on my '88
1981 Dodge D150 360 auto
[Re: lunacy]
#2114776
07/21/16 01:38 PM
07/21/16 01:38 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
That's cool, did you swap over steering columns and everything else too? How about the a/c boxes? Everything. Wiring harness, fuel tank, AC box, steering column, power brake booster, wiper motor, radiator - all come out of the 93 and went into the 75. This way I went from a 360 2bbl with 727 to a 360 MPI with a 4 speed automatic. The last step is to convert the axles to the ones out of my 72 W200. That will get me true part time 4 wheel drive. The W200 front axle has already been converted from drum brakes to GM disk brakes with locking hubs.
[Re: Morty426]
#2121729
07/31/16 04:28 AM
07/31/16 04:28 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I got a 93 dash installed into my 75 Plymouth Trailduster so there should be no issue going the other way in regards to dash / dash frame fit. I have found in a local yard a '92 D150 with a complete instrument cluster. Since it has a voltmeter and my '87 has a bypassed ammeter, I want to swap the later instrument cluster into the earlier truck. Obviously there are some differences in the dash wiring and maybe I should ask for the complete dash wiring harness to ensure success. I also have two really nice Autometer voltmeters and maybe, in the long run, it would be easier to carve up the original '87 cluster and fit the aftermarket gauge. Thoughts?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#2121793
07/31/16 11:09 AM
07/31/16 11:09 AM
Morty426
Sacramento CA
I got a 93 dash installed into my 75 Plymouth Trailduster so there should be no issue going the other way in regards to dash / dash frame fit. I have found in a local yard a '92 D150 with a complete instrument cluster. Since it has a voltmeter and my '87 has a bypassed ammeter, I want to swap the later instrument cluster into the earlier truck. Obviously there are some differences in the dash wiring and maybe I should ask for the complete dash wiring harness to ensure success. I also have two really nice Autometer voltmeters and maybe, in the long run, it would be easier to carve up the original '87 cluster and fit the aftermarket gauge. Thoughts? I didn't run into the issue because I swapped out ALL of the electrical wiring to go with the motor and trans and the dash assembly
