My understanding is, standard length LA valves and LA spring height with offset W-2 rocker shafts, blocks and rockers. The paperwork with the head castings said the development engine MoPar Perf built used a .509 hydraulic cam and 1.6 rockers (for clearance to the pushrod holes at the intake flange side). I have the castings, valves and even the .620" lift capable MoPar springs for the 1.68" installed height. Plan on using Crane/MP roller rockers/shafts and stands for a regular race W-2. It mocks up good!
