1970 B-body A-833 detailing #2112311
07/18/16 10:24 AM
07/18/16 10:24 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang...
I looked over at MMC, Roger Gibson and searched here and couldn't find any images on the detailing/markings on a A-833 18-spline 4-speed in my '70 Superbird. Unfortunately, my tranny was painted red by the original owner, so it is impossible to take reference pictures of this particular unit. I have a friend with a survivor 4speed Superbird, but there may be some markings on top I can't see...
Thanks in advance for any images...
Troy
Houston Mopar Connection Club
Re: 1970 B-body A-833 detailing [Re: hemi68charger] #2112346
07/18/16 11:34 AM
07/18/16 11:34 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
If you have the broadcast sheet you would at least have the, I believe it is called the rack number. They were in different colors and numbers depending on plant. I always figured if you don't know don't do it someone might call you out on it.
1969 Hemi Roadrunner 2nd owner
Re: 1970 B-body A-833 detailing [Re: 69hemibeep] #2112350
07/18/16 11:41 AM
07/18/16 11:41 AM
Houston, Tx
Houston, Tx
Thanks.. Not worried about anyone calling me out on it... grin
Never heard of the rack number.. Interesting.......
Troy
Re: 1970 B-body A-833 detailing [Re: hemi68charger] #2112369
07/18/16 12:29 PM
07/18/16 12:29 PM
Mass
charge70 Offline
charge70  Offline
Mass
Those are the 3 large #'s that are stenciled on the passenger side of the case.They are the last 3 #'s of the actual part# for that 4 speed
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 1970 B-body A-833 detailing [Re: charge70] #2112399
07/18/16 01:14 PM
07/18/16 01:14 PM
Houston, Tx
Houston, Tx
OK, that's what I thought they were, partial part number...
Troy
Re: 1970 B-body A-833 detailing [Re: hemi68charger] #2112454
07/18/16 02:07 PM
07/18/16 02:07 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Yes they are part #s. An old friend of mine that worked the assembly line said they sat in racks and pulled according to the build and the workers on his line reffered to that as a rack #
Re: 1970 B-body A-833 detailing [Re: hemi68charger] #2112482
07/18/16 02:51 PM
07/18/16 02:51 PM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
Re: 1970 B-body A-833 detailing [Re: hemi68charger] #2113124
07/19/16 11:23 AM
07/19/16 11:23 AM
Mass
charge70 Offline
charge70  Offline
Mass
Troy,I have a build sheet for a 70 Charger R/T 440 4bbl 4 speed,and the code in the trans box on the sheet is 676.This may help.
Re: 1970 B-body A-833 detailing [Re: charge70] #2113170
07/19/16 11:54 AM
07/19/16 11:54 AM
Houston, Tx
Houston, Tx
That helps, thanks..... But I was looking for images or either originals or restored OEM correct ones so I can see colors, font size, inspection markings, etc.......
Troy
Re: 1970 B-body A-833 detailing [Re: hemi68charger] #2113190
07/19/16 12:14 PM
07/19/16 12:14 PM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
Re: 1970 B-body A-833 detailing [Re: hemi68charger] #2113370
07/19/16 04:00 PM
07/19/16 04:00 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Mine is a 69 but I'm sure the # size is the same
