Re: Torqueflite Filter Extension O-ring
[Re: rebel]
#2110767
07/15/16 08:29 PM
07/15/16 08:29 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought a boxed kit years ago with a bunch of different sized orings in it and it has paid for itself many times over
[Re: pittsburghracer]
#2110853
07/15/16 10:23 PM
07/15/16 10:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I bought a boxed kit years ago with a bunch of different sized orings in it and it has paid for itself many times over I have the same type of thing.. about 40 different choices.. ID,OD and thickness... usually the ID and OD are set based on the thickness of the O-ring unless its something special(and that extension isnt special) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Leigh]
#2110908
07/16/16 12:13 AM
07/16/16 12:13 AM
MR_P_BODY
Sealing materials react both favorably and adversely, to fluid properties. Yes they do... as of yet I havent had any issues with trans fluid and standard O-ring material... if I had a choice all my O-rings would be viton but they are hard to find in a big kit
[Re: MR_P_BODY]
#2110969
07/16/16 03:08 AM
07/16/16 03:08 AM
Posts: 4,647 aotearoa
rebel
aotearoa
if I had a choice all my O-rings would be viton but they are hard to find in a big kit try airconditioning or refrigeration parts suppliers. Viton is used a lot in that industry.
[Re: rebel]
#2110995
07/16/16 07:40 AM
07/16/16 07:40 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Once again don't over engineer things. Viton is great and needed in rare conditions but usually not needed. Heck in the steel mill well made a lot of our own orings using bulk cut to size rubber off a reel and glueing it together and if you want to see rough conditions take a steel mill tour
[Re: rickraw]
#2111869
07/17/16 04:17 PM
07/17/16 04:17 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Can't believe this post is still going. It's a simple o-ring. Anyone that fits will work. Once its crushed against the vb $ filter case closed, it will never suck air. 2 cts. I just posted that to try to help the next guy. Sorry!!!!!!!
#2111894
07/17/16 04:59 PM
07/17/16 04:59 PM
Posts: 485 Central California
MoParFish
Central California
Can't believe this post is still going. It's a simple o-ring. Anyone that fits will work. Once its crushed against the vb $ filter case closed, it will never suck air. 2 cts. I just posted that to try to help the next guy. Sorry!!!!!!! Yep, just tryin' to help. If I needed one, I would have gone to my O-ring kit too, as it's saved me many times over. I just happened to have a MP kit and measured the O-ring "like the OP asked for". ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) No biggie...
