Who sells the grooved copper crush washers? #2110095
07/14/16 07:52 PM
07/14/16 07:52 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
For the caliper banjo bolts.
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110122
07/14/16 08:36 PM
07/14/16 08:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have never seen them grooved new. Only after they are installed do they get grooves in them.
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110125
07/14/16 08:51 PM
07/14/16 08:51 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
Most of the ones packed with the NAPA remanufactured calipers are grooved. All the ones packaged / sold as replacements I have seen are smooth. I have seen a few company's offer extra thick smooth ones.
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110128
07/14/16 08:54 PM
07/14/16 08:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
None seal as well as the originals. I always reuse them.
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110166
07/14/16 10:32 PM
07/14/16 10:32 PM
AndyF Offline
AndyF  Offline
Buy new ones over the counter at your local Dodge dealer
Re: Who sells the grooved copper crush washers? [Re: stumpy] #2110172
07/14/16 10:38 PM
07/14/16 10:38 PM
This, the new dealer ones are smooth. gently wire brush the originals and use a scribe to clean the circular grooves & an option is a very light coat of sealant (I used "the right stuff" on a toughie), no leaks
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110289
07/15/16 12:43 AM
07/15/16 12:43 AM
BDW Online content
BDW  Online Content
Re: Who sells the grooved copper crush washers? [Re: BDW] #2110302
07/15/16 12:56 AM
07/15/16 12:56 AM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
Yeah I've already tried those washers in the pic. Don't have the originals. I'm just not getting a seal.
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110317
07/15/16 01:14 AM
07/15/16 01:14 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The best way to get a good seal with the solid copper washers after the first use is to put a torch to them until they glow. It annals it and makes it soft again.
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110347
07/15/16 02:00 AM
07/15/16 02:00 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Mopar ones as said. Trust us on this one. Been there done that.
Re: Who sells the grooved copper crush washers? [Re: mopars4ever] #2110360
07/15/16 03:25 AM
07/15/16 03:25 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Re: Who sells the grooved copper crush washers? [Re: Big_E] #2110361
07/15/16 03:26 AM
07/15/16 03:26 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110385
07/15/16 08:41 AM
07/15/16 08:41 AM
BDW Online content
BDW  Online Content
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110396
07/15/16 09:19 AM
07/15/16 09:19 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Not grooved but NAPA has a variety:
https://www.napaonline.com/napa/en/search?q=Ntk%3DKeyword%26N%3D0%26Ntt%3Dcopper+washer&isApplication=false&isProduct=true&isInterchange=false&text=copper%20washer&catId=&catIndex=&sc=&page=0&sort=DFLT&pageSize=12
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110426
07/15/16 11:17 AM
07/15/16 11:17 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Make sure the problem isn't a pitted/corroded caliper sealing surface. I had a sealing issue even those thick washers didn't take care of. It turned out that the washers sealing surface on the caliper was heavily pitted and the fluid leaked right past the washer.(rebuild CARQUEST calipers) I had to sand the sealing surface to a smooth finish.
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110452
07/15/16 12:02 PM
07/15/16 12:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If not damaged I also use the old ones.Have done it at the shop and home for over 30 years.Had too many new ones leak.Rocky
Chrysler Firepower
Re: Who sells the grooved copper crush washers? [Re: fatsat] #2110482
07/15/16 01:05 PM
07/15/16 01:05 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used to have problems with them until I started to tighten and loosen them half a dozen times. This allows them to seat much better.
I do the same thing with new rocker arms and adjuster jam nuts.
