Page 103 of 180 1 2 101 102 103 104 105 179 180
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2109288
07/13/16 11:50 AM
07/13/16 11:50 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
YOUR NUCKIN FUTZ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2109586
07/13/16 08:31 PM
07/13/16 08:31 PM
N.Y.
sixpacksteve Offline
N.Y.
kuddos, sometimes i wonder. Do i wish to be this nutz. or maybe i am nuttier!
Hell Hath No Fury Like Mine
Re: Real world weight loss program and it` cost.......... [Re: sixpacksteve] #2109762
07/14/16 02:03 AM
07/14/16 02:03 AM
hemi-itis Offline
hemi-itis  Offline
This is MUCH larger than your individual nuttiness violin
You not control "IT"
"IT" controls you whistling
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2110248
07/15/16 12:01 AM
07/15/16 12:01 AM
fullmetaljacket Offline
Nutty professor I is.
You know, like the dude from Back to the Future. LOL.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2110254
07/15/16 12:06 AM
07/15/16 12:06 AM
Under the drill.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2110262
07/15/16 12:13 AM
07/15/16 12:13 AM
Hole in one.
This was the only way I saw fit to make such a cut to start off with. I was afraid the tempered aluminum was going to dull the hole saw, but it cut fairly smooth but with patience and lots of cooling fluid. Aluminum likes to obtain heat and dish it out as well.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2110268
07/15/16 12:17 AM
07/15/16 12:17 AM
All crucial holes done. Loosing weight it was.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2110270
07/15/16 12:19 AM
07/15/16 12:19 AM
Drill bits played a good role in checking crucial alignment before moving forward.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2110275
07/15/16 12:25 AM
07/15/16 12:25 AM
At this stage the block was at a lean 4.55 ounces down from 8.85 ounces. I imagine when all is said and done and the teeth locks are ground in, it will weigh in at 3.90 ounces or a good 1/4 pound plus per side shavings not including the back plates and screws.
Should be about a pound off at the end between both doors. I'll take it.
This stuff is starting to make me wonder about my sanity or lack of. LOL
Re: Real world weight loss program and it` cost.......... [Re: sixpacksteve] #2110279
07/15/16 12:30 AM
07/15/16 12:30 AM
Sixpack steve.
Yes we should all be this nuts because the world outside is even nuttier both wholesale and retail.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2111022
07/16/16 10:08 AM
07/16/16 10:08 AM
moparx Offline
moparx  Offline
t'was exactly as i thought you would carve that turkey ! i have fabbed 100's of parts over the years using similar methods just to see if i could using old school methods, even having a reasonable equipped machine shop at my disposal. it takes WAY less time making use of modern mills and lathes, but it is MORE satisfying [to me any way] to carve something the old way. you did GOOD son ! up
beer
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2113911
07/20/16 11:32 AM
07/20/16 11:32 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Just wanted to add a note here.
Went to Carlisle thinking I would get a fiberglass hood for my Duster from AAR/Stinger who always have a spot there. Didn't buy one.
Their hoods appear to be well made but they are pricey. Not faulting them for charging what they do, I'm sure it is not cheap to make them. If you don't happen to live close to them or pick one up at a show, shipping is around $160 so you're getting up into the $800 range if you decide to go with one of their parts. Seems like benefit to cost ratio might be a little lopsided.
I looked at the cowl hood they had and it just seemed to say 'look at me' a little too much. They don't make anything lower than 4", no one buys them, not even the Chebby guys. For $625, I think I made the right call. Didn't really think I wanted a Six-Pack style hood/scoop either, just too ubiquitous.
They sold the one flat hood they had which would have probably been the one I would have bought. Probably should have called ahead to reserve one but that was a fail on my part. Interestingly enough, the owner said they had more requests for flat hoods than they anticipated. I guess guys want the 'stealth' look these days.
I asked him about hood springs and he said they were working on a source for lightweight ones and may have them within a few weeks.
So thinking beyond buying a 'glass hood, I'd be interested in hearing what the best method might be for lightening a steel hood is and if it's worth doing.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2113948
07/20/16 12:10 PM
07/20/16 12:10 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
"So thinking beyond buying a 'glass hood, I'd be interested in hearing what the best method might be for lightening a steel hood is and if it's worth doing".
Same thing I'm looking at doing, cutting out most of the steel bracing and making fiberglass channels formed and bonded to the hood, just bought a used hood to experiment on.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2113979
07/20/16 12:44 PM
07/20/16 12:44 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I still think you should make two of every part so I can put them though a durability cycle at the track.
Doug
Re: Real world weight loss program and it` cost.......... [Re: Adobedude] #2113985
07/20/16 12:53 PM
07/20/16 12:53 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Hope to see what you come up with.
I was thinking about somehow using aluminum strips or something in place of the steel braces. Not sure how that could work.
Again, may not even be worth doing.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: Adobedude] #2114002
07/20/16 01:13 PM
07/20/16 01:13 PM
There are a few ways to go about this.
Chemical milling is the one way of keeping the hood as is and taking weight off depending on what amount of milling is applied.
Keep in mind that chemical milling if done to the upmost will make the hood weak and distort as the springs try to break its back when opening and closing.
The guy that dips for me is an expert and maybe you guys can have a direct chat with him here in Detroit. He really knows his percentages of dip time and metal removal being that he has done numerous hoods, fenders and doors for many cheaters in the SS market.
I would have to safely say that his procedure will be cheaper than a glass hood, though a glass flat hood from AAR/Stinger will be rather nice being that I have seen their products.
They are top notch. I really stared with contemplation at their 65' B stuff and almost pulled the trigger myself.
The other cheap "do it yourself " way is to completely carefully gut out the inner brace structure just leaving the outer skin along with the what's left of the outer rim braces and making it a pin on/liftoff hood. This procedure of course deletes the under hood hinges and springs all together. There lies a good amount of weight removed. Lift offs can be a pain in the hoots sometimes, but at least you get your exercise in. LOL.
One fact though with this second trick: The hood is only going to keep its shape when lifting off and on with the aid of an installed scoop which in your case would be the double snorkel style which in itself acts as a back brace for rigidity. I performed this trick many moons ago using the very first proto-type A-990 glass Hemi scoop and the hood was about 20 or so pounds lighter before adding in the scoop which in turn brought back the hoods weight by about 10 pounds, but it was now a slightly lighter functioning air hood.
So with that being said, A glass flat hood would shave about 35-40 Lbs depending on the stock hoods factory weight. But a flat hinge hood will be a little heavier than a lift off because of all the hood hinge reinforcements. I've seen some glass hoods to be shy of just 10 Lbs from their steel counterparts.
An Acid hood would shave about 25-28 Lbs pounds at most, again depending on what the percentage of removal is and a pin on steel hood would maybe shave 12-18 Lbs.
Most of the weight on these hoods are the outer skins where most of its mass sits.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2114047
07/20/16 02:07 PM
07/20/16 02:07 PM
It would have been nice if the Feather Duster hoods were interchangeable with other years and Demons, but not much weigh savings, though I would take it if it were the case
Now a days presumedly, aluminum hoods are found on Challengers, Chargers and Mustangs just to name a few. There's half your work right there. Lucky new boomers. LOL
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2114073
07/20/16 02:52 PM
07/20/16 02:52 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Copied the inner splash shield in Fiberglass. Painted black, clipped in the rubber seals, and installed with aluminum hardware. Saved 1.5 lbs a side.
Also made fender rods from aluminum tubing, swapped to aluminum hood pins and started making Aluminum bumper brackets, those aren't quite finished yet.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Real world weight loss program and it` cost.......... [Re: OUTLAWD] #2114089
07/20/16 03:05 PM
07/20/16 03:05 PM
Very neat.
Wow, it seems like Fiber glass molding has come a long way in favor of the back door tricks in that it is fairly easy to make such complicated pieces.
Aluminum pins save a good number for what they serve. Some companies have been making them for years, especially the stock car crowd.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2114238
07/20/16 05:53 PM
07/20/16 05:53 PM
I stand corrected as of an hour ago. The Dipper usually shoots for 20% off as far as metal removal so a 15 or so Lbs shavings is expected from the stock weight.
It may not sound like much, but when you factor in the fenders, bumpers, doors and other misc stuff, subtractions adds up.
