HP Manifold Heat Riser #2110057
07/14/16 06:38 PM
07/14/16 06:38 PM
Ohio
Claudia Offline OP
Claudia  Offline OP
Ohio
Looking for some advise on the heat riser in the big block HP manifold. Thinking about either tac welding it open or just removing it completely and welding up the two holes. Advantages or disadvantages? Any input is appreciated.
Re: HP Manifold Heat Riser [Re: Claudia] #2110143
07/14/16 09:32 PM
07/14/16 09:32 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
With my HP manifold, I just had the heat riser removed and the holes welded up. Didn't want any restrictions or any worries from it. I'm sure it would be fine also to weld it open if you have seconds thoughts about removing it. As long as there are no restrictions in the exhaust!
Re: HP Manifold Heat Riser [Re: Claudia] #2110247
07/14/16 11:59 PM
07/14/16 11:59 PM
Ohio
Claudia Offline OP
Claudia  Offline OP
Ohio
Anything special needed to weld the holes in the manifold?
Re: HP Manifold Heat Riser [Re: Claudia] #2110358
07/15/16 03:16 AM
07/15/16 03:16 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
This is my plan;
The_look
Re: HP Manifold Heat Riser [Re: Claudia] #2110413
07/15/16 10:36 AM
07/15/16 10:36 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
I just did a manifold for my turbo slant six. My machinist just threded the holes and used plugs. No risk of cracks that way. Maybe you can thread that stud in there.
Re: HP Manifold Heat Riser [Re: Claudia] #2110556
07/15/16 03:28 PM
07/15/16 03:28 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
On my HP manifolds I wanted to keep the stock look. I removed the disc (valve) and ground the shaft flat so it presented a minimum of surface area to the exhaust flow. If stock looks don't matter, Killermopar's threading idea sounds like an excellent option.
