Hood Pin hole location for a Cuda #2109688
07/13/16 11:49 PM
07/13/16 11:49 PM
Central Pa.
Cloned_Cuda Offline OP
Central Pa.
Does anyone make a template or have a drawing to show where to locate and hole sizes.
Thanks!
Re: Hood Pin hole location for a Cuda [Re: Cloned_Cuda] #2109703
07/14/16 12:12 AM
07/14/16 12:12 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
You have the pin brackets right? Install them then let the position of the pins determine the holes. There are relief holes in the hood sub structure too.
Re: Hood Pin hole location for a Cuda [Re: Cloned_Cuda] #2109999
07/14/16 04:57 PM
07/14/16 04:57 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
You have an e-mail
Re: Hood Pin hole location for a Cuda [Re: Cloned_Cuda] #2110793
07/15/16 09:07 PM
07/15/16 09:07 PM
Central Pa.
Central Pa.
Thanks for everyone's help and I do have the pins and brackets.
