Can you use the factory drum brake booster with a front disc master?
Maybe... it depends. First question is does the master bolt up and is the pushrod the right length?
If it does bolt up and work is there enough braake line pressure for the front discs? It depends in part on the piston area of the front calipers used and also on the master diameter.
I made the front disc swap on a car with drum booster and small piston area aftermarket front calipers. It worked OK on the street but I could not get max effort braking. With my setup, a double diaphragm 8" booster and smaller 15/16" diameter master was needed for full "stop power".
Hopefully somebody who has made this swap on a PU will comment or Scarebird will have some suggestions.
