Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2114271
07/20/16 06:49 PM
07/20/16 06:49 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
This is the opposite of what I plan on doing. This Dakota hood was made into a cowl hood, I'll remove what bracing I can and leave the skin but as you can see there's a lot of weight I can remove. I have a spare hood I'll be cutting up just in case it turns into junk.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2114277
07/20/16 06:57 PM
07/20/16 06:57 PM
fullmetaljacket
At least that Dakota hood is aero. Lots of webbing to remove. It could be rather easy to remove and put on if it were a pin on. The shorter the skin stretch, the better.
[Re: Thumperdart]
#2114326
07/20/16 08:42 PM
07/20/16 08:42 PM
Adobedude
New Mexico
It'll be a pin on hood, hinges and springs are massive.
[Re: Thumperdart]
#2114710
07/21/16 12:30 PM
07/21/16 12:30 PM
Adobedude
New Mexico
One thing I like about the older Dodge trucks, it's not "Death by Grill".
[Re: Thumperdart]
#2115221
07/21/16 11:35 PM
07/21/16 11:35 PM
Adobedude
New Mexico
All the above, there isn't one area you focus on, you have to hit everything. But, last time I was on the scales I was 600 lbs heavy over the nose.
[Re: Thumperdart]
#2117946
07/26/16 09:53 AM
07/26/16 09:53 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Anyone use Lexan windows from Pro Glass? I have read about them recently, they make formed windows that install like stock with gaskets etc. They are not real expensive for what they are. I looked into it, the windshield on my Duster is starting to delaminate a little around the edges, might be a good opportunity to shave some weight off the front while looking stock. Pro Glass
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2117989
07/26/16 11:25 AM
07/26/16 11:25 AM
fullmetaljacket
Pro-glass has nice formed windows and I installed one of them in the Duster for Glasses. He had some water leakage around the cowl area but I believe it was a rusted hole or so or the fact that I did not seal the Pro-glass entirely with silicone to create the problem. Other than that, it saved a good amount of pounds and looked stock. He even used his wipers on it for some time. I recommend not using wipers since most of these types of cars are the worlds best weather stations. If it's gonna rain, keep it in the garage, if it's gonna be wonderful out side, the car will be prowling the streets. Visual maintenance: Polish it every so often with good soft cloth rags and plastic polish and the glass will look great.
[Re: Adobedude]
#2118310
07/26/16 05:37 PM
07/26/16 05:37 PM
Posts: 126 Oregon
Jamie McGrath
This is the opposite of what I plan on doing. This Dakota hood was made into a cowl hood, I'll remove what bracing I can and leave the skin but as you can see there's a lot of weight I can remove. I have a spare hood I'll be cutting up just in case it turns into junk. Lay out some fine mesh or screen give it a lite primer dusting too see the spots and start Swiss Cheezing the braces.
[Re: fullmetaljacket]
#2120759
07/29/16 05:37 PM
07/29/16 05:37 PM
fullmetaljacket
Here's what some Witching hour spare time in the cellar here in Detroit can start to produce. The main cavity is now rough cut and I will go in with my dentist tools and carve out the latch catch teeth. This aluminum is super hard. More later.
