DICS TO DRUM FRONT DANA 44 CONVERSION #2104322
07/05/16 04:58 PM
07/05/16 04:58 PM
SC
BowtieKillr Offline OP
SC
What years can I get the front axel out of to change my 1972 dana 44 front drums to disc's.
Thanks !!
Re: DICS TO DRUM FRONT DANA 44 CONVERSION [Re: BowtieKillr] #2104651
07/06/16 02:14 AM
07/06/16 02:14 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Ideally I do believe its 81-84, they had hubs and weren't the center axle disconnect. BUT because of the divorced transfer case you will have a terrible driveshaft angle with a newer one. So you can use shims OR convert your old axle. Here is a link for doing it with chevy parts, but you can use the outers from dodge from 81-93 instead
http://www.offroadexchange.com/diskbrakeswap.htm
Re: DICS TO DRUM FRONT DANA 44 CONVERSION [Re: BowtieKillr] #2108944
07/12/16 08:24 PM
07/12/16 08:24 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
80 and up
Re: DICS TO DRUM FRONT DANA 44 CONVERSION [Re: 76dodgeboy] #2109740
07/14/16 01:13 AM
07/14/16 01:13 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Could also use just everything from your stub shafts out on your housing and inner shafts. That would also mean you could pilfer the stuff off a later 80's one with center disconnect.Lots of 73-79 ford half ton guys do the same to get 3/4 ton ends, because 3/4 tons also had 44 fronts.A rear swap. and you have a 3/4 ton truck. The ford guys like it because they get to keep a comfy coil spring front end that way.
