Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW #2107125
07/10/16 01:56 AM
07/10/16 01:56 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
If I was made of money I would buy this.
http://newyork.craigslist.org/brk/cto/5674803205.html
Re: Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW [Re: RUMBLON] #2107127
07/10/16 01:59 AM
07/10/16 01:59 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Is that drive shaft going to hold up?
Re: Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW [Re: RUMBLON] #2107206
07/10/16 10:48 AM
07/10/16 10:48 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I'd have some concern on those drive shaft angles. The front one looks to be way more then the 30 degrees a u-joint can handle, and the rear joint looks to be nearly straight. I suspect there is some major drive line vibration going on there. Probably why "some mechanical skills are required to finish this build". They screwed up the drive shaft angles and don't know how to fix it, or it will be a major pita to fix it.
That's a lot of money for something not yet road worthy, on a new build. Makes me wonder what else they screwed up. Gene
Re: Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW [Re: RUMBLON] #2107220
07/10/16 11:19 AM
07/10/16 11:19 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looks like in the quest to get it to set as low as possible they sacrificed everything, including the ability to drive it.
Don't be the exception.
Re: Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW [Re: RUMBLON] #2107648
07/11/16 12:50 AM
07/11/16 12:50 AM
Freeport IL USA
Freeport IL USA
There is a price to pay to get things as low as possible! Gene
Re: Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW [Re: RUMBLON] #2107651
07/11/16 12:57 AM
07/11/16 12:57 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I wonder what the frame was from originally?It is some sort of OE manufacture with tubes added and possibly an aftermarket independent front grafted on.Welds look a little...thick maybe? Nice trailing arms on it.
Re: Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW [Re: RUMBLON] #2116950
07/25/16 12:10 AM
07/25/16 12:10 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Wow !!
Re: Any thoughts on this 47 DODGE CUMMINS TRUCK? WOW [Re: RUMBLON] #2118991
07/27/16 12:43 PM
07/27/16 12:43 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
In the pics where the driveshaft angle at the diff looks flat I don't think the engine is in. Driveshaft angles don't look to horrific in my novice opinion, no worse than what they were in my 78 Warlock I had and that had no vibrations. It is a very sweet truck and well worth the money IMO
