Carb help needed please! #2107457
07/10/16 07:28 PM
07/10/16 07:28 PM
Oak Harbor, WA
W
Wicked49670dart Offline OP
W
Oak Harbor, WA
Fired up my freshened up 496 and ever since has a stumble hot. Plugs are light gray in color, I use VP 110. Idles smooth at 1200 RPM, but has stumble right of idle. Carb is a 4150 1000 cfm Pro-systems carb. Tried richer on mixture screws, still the same problem. Timing at 34 degrees. I did change the cam to 274/280 from a 268/272 flat tappet.
Primary Main 84
hi air 32
idle air 76
idle feed 35
PV 6.5
Thanks Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Carb help needed please! [Re: Wicked49670dart] #2107466
07/10/16 07:47 PM
07/10/16 07:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do you have a wideband.........How much t-slot exposure do you have w/butterflies closed cos a .076 is a bit lean unless you have major t-slot exposure. Stumble like blubber rich or like falls on it`s face.........
Re: Carb help needed please! [Re: Wicked49670dart] #2107471
07/10/16 07:52 PM
07/10/16 07:52 PM
Australia
P
Project kickin A Offline
P
Australia
maybe lengthen the acc pump adjuster a wisker tad.... I run my timing at 32 total not that it has any effect on an off idle stumble
Re: Carb help needed please! [Re: Wicked49670dart] #2107480
07/10/16 08:07 PM
07/10/16 08:07 PM
Mark Whitener Offline
Does it stumble cold?
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Carb help needed please! [Re: Wicked49670dart] #2107504
07/10/16 09:06 PM
07/10/16 09:06 PM
AndyF Offline
AndyF  Offline
1200 rpm is fairly fast so you might have the throttle blades open too far. Check your t-slot exposure like mentioned above. If your throttle blades are open too far then you should close them and either open the secondaries a small amount or drill holes in the throttle blades. You want the throttle blades set so only a small portion of the t-slot is showing at idle. Once those are set correctly then you can start figuring out if you are lean or rich at idle. Get the idle sorted out then figure out if you are lean or rich at cruise.
Re: Carb help needed please! [Re: Wicked49670dart] #2107612
07/11/16 12:08 AM
07/11/16 12:08 AM
Primary Main 84
hi air 32
idle air 76
idle feed 35
PV 6.5
Thanks Matt
Did you degree this cam in off the cam card or lobe seperation angles? If not maybe it is time to do that twocents Light grey with race gas is probally a little richer than I would run it, try leaning the idle AFR down to see if that helps scope I've seen motors stumble both from being to lean and to rich shruggy
Re: Carb help needed please! [Re: Cab_Burge] #2107674
07/11/16 01:38 AM
07/11/16 01:38 AM
to me it is idling way way too fast, then with that lowered I'd want to know what the initial is
Re: Carb help needed please! [Re: AndyF] #2107676
07/11/16 01:41 AM
07/11/16 01:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree... at that throttle position can you turn in
the mixture screws and kill the engine... you might be
open too far and are not in the idle circuit anymore and
make sure the pump starts to move as soon as you touch
the throttle.... and is it warmed up... cold it would
want to be fatter(think choke)
wave
Re: Carb help needed please! [Re: MR_P_BODY] #2108461
07/12/16 01:59 AM
07/12/16 01:59 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks for all the suggestions! Dom thanks for your time on the phone, your suggestion did help a lot! Will call you soon for that new carb! Matt
Re: Carb help needed please! [Re: Wicked49670dart] #2108475
07/12/16 02:16 AM
07/12/16 02:16 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It needs to be cleaned up but I think a 1050 dommy will out perform that thing.............
