Re: Camshaft properties for e85 build
[Re: momopar]
#2107312
07/10/16 02:41 PM
07/10/16 02:41 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you are going to run only E85 it makes sense to optimize for E85, which means keep the compression up.
[Re: momopar]
#2107328
07/10/16 03:02 PM
07/10/16 03:02 PM
Posts: 407 NE Indiana
momopar
NE Indiana
I have the old (heavy) 2295s and plans are to go stroker in the future with 13:1.Yes this is a dedicated e85 build since living in the midwest we have about 10 places that carry the stuff within 15 miles from home.
The future plans to stroke it (or just build another based on a low deck) is why I'm going with the 1050 (4150) e85 carbs ain't cheap so I might have to jet down for the 446.
I be prepared though for future plans eh? I ran this old hog for years with the 2295s and and old .471/.474 Hemi cam.
It did not like pump gas and racing gas is lots o' dollars and not available locally.
I have Crane iron 1.6 and am for sure going solid flat tappet on this build. There was some write-up about e85 camming that you could go 10* or more bigger than pump gas? Just thinking when choosing a cam there may be something better to shoot for,,,,,,,,,,,,,,,,,,,,,,,,,,or not?
[Re: momopar]
#2107330
07/10/16 03:06 PM
07/10/16 03:06 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Cam doesn't care what the fuel is. Carb, Compression & timing does.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2107333
07/10/16 03:10 PM
07/10/16 03:10 PM
Posts: 21,824 Kirkland, Washington
Pacnorthcuda
Cam doesn't care what the fuel is. Carb, Compression & timing does. The intake closing event has a direct effect on dynamic compression. An optimized cam in this case will most assuredly be different for E85 vs gasoline.
[Re: Pacnorthcuda]
#2107338
07/10/16 03:20 PM
07/10/16 03:20 PM
DARTH V8Я
Its a TRAP!
Cam doesn't care what the fuel is. Carb, Compression & timing does. The intake closing event has a direct effect on dynamic compression. An optimized cam in this case will most assuredly be different for E85 vs gasoline. So what. 268 cam has different IVC then a 272, or retard the cam to close the valve sooner. With 13:1 you're gonna have a high DCR anyways.
[Re: momopar]
#2107454
07/10/16 07:26 PM
07/10/16 07:26 PM
DARTH V8Я
Its a TRAP!
Well with performance cams, you are going to find that the bigger the cams duration, the later the intake closes. Which essentially bleeds of more DCR.
Only sure fire way is to raise the compression. And with E85, raise it a lot.
[Re: momopar]
#2107486
07/10/16 08:14 PM
07/10/16 08:14 PM
Supercuda
About to go away
About to go away
up yours
Not always, get a wide lobe separation and it'll be a better fit. Don't be getting no old school cams though.
[Re: momopar]
#2107740
07/11/16 07:23 AM
07/11/16 07:23 AM
momopar
NE Indiana
Looking at a Howards 254/260, too much eh? I can tolerate loosing some on the lower end. NOT a dedicated strip car, more of a get it out and play toy? '69 Coronet 3.23 most of the time (I have a complete 4.57 pig also)No fiberglass stuff so 3800-3900#. High stall 11" probably flashes ~3000 with the old Hemi cam (284 what's that 237*)
That old hydraulic had some lope but I think I would like just a bit more. I have read many places a solid needs 10 more degrees than a hydraulic?
So looking at it that way, 240 solid would be a "smaller" cam than the old 284 hydraulic. I see you are making sense, but,,,,,,,,,,,,,,,, some people just need a hammer to the head to get it?
I looked at the Hughes cams, but they seem like a whole bunch of lift for the duration, especially with 1.6 rockers (measured a bit more than that) Well thanks for the help, I will continue my quest.
[Re: momopar]
#2107889
07/11/16 02:16 PM
07/11/16 02:16 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
I wouldn't hesitate to use a cam like your thinking with 106 to 108 LSA and install it at 102 to 105 intake lobe center One of the best HP and torque producing 906 iron headed pump gas stock stroke 440 motors I built had a Reed cam with 101 LSA(installed at 99 ILC) similar duration like your thinking and .560 lift with 1.5 ratio rockers That racal had a bunch of tire spinning bottom end and it would not quit pulling hard up to 7000 RPM according to the customer Back when I first started learning about camshafts we would use a close (104 to 108 )LSA on the automatic cars and a wider(110+) LSA on the stick shift cars, the thinking was and is the closer LSA help the bottom end, below 5000 RPM, and the wider LSA move the peak power up above 5000 RPM That still applys for me BTW, my bracket motor(505 C.I., 14.3 to 1 comp. ratio) runs on pump E85 with a 108 LSA solid roller cam installed at 106 ILC, runs good, last a long time after I got the rocker arm situation worked out on the Eddy M. M.W. Victor heads Make sure your fuel system will provide enough volume(30% more needed at least than for gasoline) for running on E85
[Re: momopar]
#2109791
07/14/16 07:16 AM
07/14/16 07:16 AM
momopar
NE Indiana
Nice Torque number!
That cam have a nice chop?
The old street Hemi grind had a decent lope,,,,,,,,,,, until officer friendly persuaded me to put pipes out past the bumper.
It took away alot of that cams character. Going 3 inch with ultraflos now. (To the bumper) I know I need to use my sense on choosing a cam, but hearing a super choppy cam sure does strike a primal chord in me. ( and many others it seems)
Numbers like that don't lie, what is the mm lobe? Mopar .904 specific?
[Re: momopar]
#2110863
07/15/16 10:40 PM
07/15/16 10:40 PM
Cab_Burge
Thanks Mr. Cab,
that Howards cam comes with a 4 degree advance ground in according to the specs LSA 108* ICL 104*.
If I go this route I'll check it and perhaps put it in at 102*? Degree it to get the intake lobe center where you want it, it might end up at 101, 103 or 105 instead of 102, 104 or 106 depedning on the timing set, camshaft pin and crankshaft keyways One degree camshaft timing differences doesn't normally make a bunch of difference at the track or on a engine dyno Once you have the ILC where you like make sure and check the exhaust lobe center to verify that the cam is ground on the LSA that the cam card says it is , not all of the cams are ground correclty If the cam is ground on a 108 LSA and you install it at 104 ATDC on the intake lobe center the exhaust lobe center should be in at 112 BTDC If it is off more than one degree on the LSA send it back and have them grind you one on the correct 108 LSA
