Holley Carb ID w/o Choke Horn
#2106987
07/09/16 09:26 PM
07/09/16 09:26 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Going to look look at a Holley tomorrow, but it has a milled off choke horn, hence no list. Is there a easy way to ID say a 650, 700, 750, 800 cfm carbs?
THanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Holley Carb ID w/o Choke Horn
[Re: DARTH V8Я]
#2107113
07/10/16 01:27 AM
07/10/16 01:27 AM
DARTH V8Я
Its a TRAP!
Thanks for the reply, but I'm almost positive that 650-800 cfm Holley's use the same 1-11/16 throttle bore diameter.
[Re: DARTH V8Я]
#2107249
07/10/16 12:26 PM
07/10/16 12:26 PM
DARTH V8Я
Its a TRAP!
Going by what the seller said, yeah it was milled (most likely cut) off.
[Re: DARTH V8Я]
#2107367
07/10/16 04:11 PM
07/10/16 04:11 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There's a raised casting number on the driver side upper forward corner of the main body, right below the air cleaner flange.
Some of the ones I know are:
P-32 is an 850 CFM
P-11 is a 700
P-36 is a 780
P-80 is a 750
Post the number here and others might be able to cross that casting number to a LIST number.
[Re: DARTH V8Я]
#2107459
07/10/16 07:30 PM
07/10/16 07:30 PM
DARTH V8Я
Its a TRAP!
Dude bailed on me today.. this week sometime he said. Anyways he threw out some #'s:
rear metering block: 7003 33101 front metering block 5271 33101
he didn't give me P-xx #'s. Thanks for the info
[Re: DARTH V8Я]
#2107894
07/11/16 02:23 PM
07/11/16 02:23 PM
John_Kunkel
Rio Linda, CA
rear metering block: 7003 33101 front metering block 5271 33101 Those are for a LIST #3310...750 or 780 CFM vacuum secondary depending on the dash number.
