Coolant Concerns #2106762
07/09/16 12:03 PM
07/09/16 12:03 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
The overflow bottle in my 1971 Dart Swinger has brown and muddy looking liquid in it. I removed the radiator cap and saw the same brown and muddy looking liquid. So I'm thinking it's time for a radiator flush. I opened the petcock and out flowed crisp clean lime green anti-freeze. What is going on? confused
Re: Coolant Concerns [Re: Got2Gnow] #2106775
07/09/16 12:31 PM
07/09/16 12:31 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The sludge settles out. Do the flush- easy peasy.
Re: Coolant Concerns [Re: Got2Gnow] #2106783
07/09/16 12:45 PM
07/09/16 12:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Anti freeze is heavier than water, then water and then oil is lightest and it is at the top when it sits/settles out.
It sounds like you have oil and coolant mixing...not good.
I'd flush it hot and only use water this time and see if it mixes again which I bet it will. That way you won't waste anti freeze since it's summer time now. Just don't forget to put anti freeze back into it this fall if it turns out OK.
