Re: Jesel adjusters for pushrod oiling vs spray bars?
[Re: Charger453]
#2106659
07/09/16 01:53 AM
07/09/16 01:53 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Afaik, Jesel doesn't make any specific adjuster for spray bar oiling. They pretty much assume the rockers will be pushrod oiled.
A .020 hole for each lifter/rocker would certainly be plenty of oil, especially when you consider how little oil can squeeze through the area of a proper edge orifice oiling set up.
[Re: Charger453]
#2106676
07/09/16 02:36 AM
07/09/16 02:36 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
every motor I build gets a .030" restrictor in the pushrod, would get solid adjusters and be done with it..
[Re: Charger453]
#2106745
07/09/16 11:18 AM
07/09/16 11:18 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
On the paired shaft Jesel non alumimun rockers I have the adjusters are hollow also and there is no provisions to oil the shafts or valve tips other than splash oiling I think my Manton pushrods have a. 080 restrictor in them I'll check as I haven't put oil in that motor or even primed it yet I am using the Comp AMC solid roller lifters in it with one oiling hole in the lifters plugged.
[Re: mopar dave]
#2106922
07/09/16 06:05 PM
07/09/16 06:05 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not sure but maybe t&d adjusters will work. They offer both style adjuster but they are pricey as well at 14-16 dollars each. I know someone that may sell a set. LOL
[Re: mopar dave]
#2106992
07/09/16 09:35 PM
07/09/16 09:35 PM
Cab_Burge
Not sure but maybe t&d adjusters will work. They offer both style adjuster but they are pricey as well at 14-16 dollars each. All the good heat treated adjusters are around that price, depending on which brand and who you buy from The last set I bought for my Hughes cyro treated rockers where the same price,$13.50+ each plus shipping
