Re: Door and trunk locks
[Re: moparx]
#2106278
07/08/16 03:17 PM
07/08/16 03:17 PM
Posts: 16 Dayton, Ohio
capnbabs
Dayton, Ohio
do you have any pics of the lock cylinders used in the doors ? if i remember right, the trunk lock cylinder is in the handle, right ? Correct, trunk lock is in the handle, I'll likely go the locksmith route on that one. I'll have to get you pics of the locks when I get it back from the shop... The passenger side still has the cylinder, but no cover.
[Re: capnbabs]
#2106572
07/08/16 11:36 PM
07/08/16 11:36 PM
Posts: 10,638 Freeport IL USA
poorboy
Freeport IL USA
Finding something that fits into the original door holes is going to be tough. I've installed the door latches, handles, and striker plates from several modern cars & trucks over the years, but by the time your done, you will exceed that "over priced $50 door latch". The modern stuff needs to be slightly modified, and the original door will need to be cut, and re-welded. The advantage of using the modern stuff it they are better latches, more easily available, and can be had with power unlock fobs.
Pictures of how much was cut from the doors on my 47 Plymouth to add the Dakota door latches, and what the pre painted finish looked like. Gene
[Re: capnbabs]
#2107228
07/10/16 11:37 AM
07/10/16 11:37 AM
poorboy
Freeport IL USA
A remote trunk lock with a key fob can be adapted to your trunk lock. If you use one with a cable backup, you can hide the cable release inside the driver area.
Also, If I remember correctly, the original door locks were separate from the latches, once the lock is removed, a small square (3/16" maybe) key stock can be inserted into the lock actuating lever and can be used to lock and unlock the door (provided the latch mechanism is OK). I made a loop on the end of the square key stock so I could easily turn it. You can install a cover over the original key lock hole (if you desire) to hide the hole and help keep the weather out of your door. Then, you slide the cover out of the way, insert the square stock into the lock lever, and turn it like you would a key. I believe the key stock was about 2 1/2" long (it was a long time ago).
My car is a business coupe, I've added a 12" area between the back of the seat and the truck space that is accessible from inside the car (would have been the original location of the spare tire and the salesman storage rack, but about 2x as deep). The two doors for the storage area have separate locks and there is a divider between the two sides. On the driver side, I have a tool box, a quart of oil, a gallon of water, and a few other accessories one might need for a roadside emergency. The other side is a lockable area for the wife. In there is a package containing a couple of hooded sweat shirts, a small blanket, and a couple of rain ponchos, plus about about a 12" wide, 12" deep, and 14" high storage area for whatever she wants to lock up. A lot of times my wife will store her purse there if we stop someplace she doesn't want to carry it, or she will put in treasures she has bought in our travels. Gene
[Re: capnbabs]
#2107922
07/11/16 03:01 PM
07/11/16 03:01 PM
poorboy
Freeport IL USA
The key lock assembly is a separate piece from the latch assembly, and it is a separate piece from the door handle. The lock assembly is attached to the door handle with a screw. The door handle and the door lock are connected to the door latch by small diameter rods. There is a square rod that extends out the back of the lock assembly. That square rod engages into a square hole in the latch assembly. When you turn the key, you are turning that square rod. Once the lock assembly is removed, that square hole in the latch is empty.
You can insert the correct size square rod (also called square bar stock or square key way stock) into that hole, and turn it clockwise or counter clockwise and you can operate the lock and unlock function in the latch assembly, provided it is not seized up.
With the lock removed, you stick the square rod through the hole in the door where the lock used to be, engage the square rod into the hole in the latch, (it gets easier with practice) and use the square rod as a key to lock and unlock the latch assembly. The square rod only needs to be long enough to engage in the square hole in the latch, and extend out past the door surface far enough to be able to turn it. Adding a flat piece, or making a loop on the part of the square rod that is outside the door surface will make it easier to turn the square rod in the latch assembly. Gene
[Re: capnbabs]
#2108581
07/12/16 10:52 AM
07/12/16 10:52 AM
Posts: 19,609 north of coder
moparx
what is your paint like ? if it's just "patina", and you want, or are going to keep it like that, get a piece of 22g or so stainless [or any material for that matter] form it to the desired shape, and use a small, stainless sheetmetal screw or rivet to attach it to the door skin. use a thin nylon washer under the cover sized to the screw or rivet used to act like a slide for cover. to operate, pivot the sheild out of the way, insert lock "key", when done, pivot cover back into position. if using a screw, some loctite on the screw threads will prevent the screw from loosening during use. or another option, if you have a round hole, would be to use a metal snap in plug such as found in the hardware store for various purposes. just a couple of cheapo solutions. i don't know how big a hole you are working with.
[Re: moparx]
#2109321
07/13/16 12:49 PM
07/13/16 12:49 PM
capnbabs
Dayton, Ohio
what is your paint like ? The paint is old but all there with no rust or patina, and it's going to be redone, hopefully this fall. Thanks again for all of the ideas fellas! I'm considering both your suggestions and getting a set of similar but non mopar locks from the same era... Found a set of Ford locks on eBay that look damn similar for 36 bucks. I'm grateful for having y'all respond! BTW, do any of y'all know how to set it so that I get email alerts when one of you fine folks responds to my post? I have to check periodically currently and it sure would be nice to get to respond to you folks s lot quicker lol!
