383 Four Barrel Emblem Application #2105351
07/07/16 12:25 AM
07/07/16 12:25 AM
Missouri
68KillerBee Offline OP
Missouri
I have a 383 four barrel emblem with three studs on the back. PN: 3504233
Through searches I have not found what this fits. I was guessing it was 1970's Challenger and Charger but don't know for sure. Photobucket is messing up and I can't put a picture up yet.
Thanks for any help
Re: 383 Four Barrel Emblem Application [Re: 68KillerBee] #2105394
07/07/16 01:25 AM
07/07/16 01:25 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
My JH27N0B Challenger has 383 Four Barrel emblems on the fenders. I'm not sure if they have 3 studs but probably do, and most likely that's what you have.
Re: 383 Four Barrel Emblem Application [Re: 68KillerBee] #2105434
07/07/16 02:32 AM
07/07/16 02:32 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
3504223 is '70 Challenger
3505444 is '71 Challenger
I thought there was a # for '71 Charger w/2 soldered on pins (I think I have a couple around here), but cant find it/them. work
Re: 383 Four Barrel Emblem Application [Re: 68KillerBee] #2105567
07/07/16 11:48 AM
07/07/16 11:48 AM
Missouri
Missouri
So 1970 non RT cars with 383's.
Re: 383 Four Barrel Emblem Application [Re: 68KillerBee] #2105643
07/07/16 01:32 PM
07/07/16 01:32 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
It is also used on 1970 and 1971 Plymouth Barracuda's which came equipped with a 383+4. They are mounted on both fenders about half way up the leg of the fender.
Re: 383 Four Barrel Emblem Application [Re: m46rat] #2105734
07/07/16 04:19 PM
07/07/16 04:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
parts catalog shows:
1970 Barracuda - "383 FOUR BARREL" #2579804
Re: 383 Four Barrel Emblem Application [Re: 68KillerBee] #2105800
07/07/16 06:17 PM
07/07/16 06:17 PM
MD
floyd Offline
floyd  Offline
MD
How big are the studs? Are they big like this or smaller?
Re: 383 Four Barrel Emblem Application [Re: 68KillerBee] #2105930
07/07/16 10:35 PM
07/07/16 10:35 PM
Missouri
Missouri
Re: 383 Four Barrel Emblem Application [Re: 68KillerBee] #2105945
07/07/16 11:03 PM
07/07/16 11:03 PM
Milwaukee WI
R_Blaha Offline
R_Blaha  Offline
Milwaukee WI
I believe those 3 studs are for the shaker bubble, someone correct me if I'm wrong.
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: 383 Four Barrel Emblem Application [Re: R_Blaha] #2105981
07/07/16 11:51 PM
07/07/16 11:51 PM
MD
floyd Offline
floyd  Offline
MD
That's what it looks like to me. But I have only seen "383 Magnum" shaker emblems before. Would they have done "383 Four Barrel" for non-R/T Challengers? Shaker emblems have the three studs and the studs are longer and thicker (I think).
Re: 383 Four Barrel Emblem Application [Re: floyd] #2106016
07/08/16 12:50 AM
07/08/16 12:50 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
here's the 340-FOUR BARREL SHAKER emblems (the "U" to "R" pin spacing is different compared to the OP's emblem)
& my 383-MAGNUM SHAKER emblems
the pins are larger than the ones for sheetmetal scope
and a pic of a 383-FOUR-BARREL emblem that had two soldered pins on the back, but don't know the part number - I have more pics of them somewhere????
