Page 3 of 4 1 2 3 4
Re: Car lift for your shop [Re: bobs69] #2105100
07/06/16 06:42 PM
07/06/16 06:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
My slab will be 4.00" but I'll have 36" squares of 8.00" thick where the lift legs will be anchored, and I'm shoring them up with some re-bar as well.
Re: Car lift for your shop [Re: ScottSmith_Harms] #2105626
07/07/16 12:55 PM
07/07/16 12:55 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Wow, why so thin for shop?, it's not a side walk.
Re: Car lift for your shop [Re: Challenger 1] #2106044
07/08/16 02:05 AM
07/08/16 02:05 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I always thought these were interesting....
Re: Car lift for your shop [Re: bobs69] #2106054
07/08/16 02:30 AM
07/08/16 02:30 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Pretty standard around here, I have 5 friends in the area with 4.00" floors in thier shops, they hold up just fine (actually 4.5" is where mine will be). Bed of 12.00" compacted crushed rock, .006 vapor barrier, 2.25" thick foam sheets, 6"x 6" steel wire grid mesh on top of the foam, 5/8" PEX tubing for the radiant heat, a grid of 1/2" rebar on 12.00" centers above the tubing. 5 sack mix concrete and It'll be PLENTY strong for home shop use.
Re: Car lift for your shop [Re: ScottSmith_Harms] #2106062
07/08/16 02:40 AM
07/08/16 02:40 AM
Central Valley, CA.
Central Valley, CA.
Pretty standard around here, I have 5 friends in the area with 4.00" floors in thier shops, they hold up just fine (actually 4.5" is where mine will be). Bed of 12.00" compacted crushed rock, .006 vapor barrier, 2.25" thick foam sheets, 6"x 6" steel wire grid mesh on top of the foam, PEX tubing for the radiant heat, a grid of 1/2" rebar on 12.00" centers above the tubing. 5 sack mix concrete and It'll be PLENTY strong for home shop use.
That will hold up fine....I oversee all construction for a fairly large city...and many of our older fire stations only use 8" of concrete in a fire station apparatus bay floor....and fire trucks are pretty darn heavy.
Re: Car lift for your shop [Re: ScottSmith_Harms] #2106215
07/08/16 01:15 PM
07/08/16 01:15 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The only problem I see with that is the anchors going into the PEX tubing for the radiant heat. I have a thicker floor than that and I still have decided a 4 post is best for me. I wish I had heat in the shop floor, but I am happy with what I have.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Car lift for your shop [Re: bobs69] #2106246
07/08/16 02:01 PM
07/08/16 02:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I routed the PEX around the areas that will have hoist pads and marked the corners so there will be no chance of drilling through PEX.
Re: Car lift for your shop [Re: rowin4] #2106252
07/08/16 02:19 PM
07/08/16 02:19 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Originally Posted By rowin4
I don't get the storage problem with a 2 post remarks. Aren't you suppose to leave a car on a 2 post? I have used my 2 car garage with 3 cars in it for years. The only advantage of a 4 post that I can see is you have a big shelve to pile more crap.
: iagree
Two post all the way!
Four post if you mostly use it to store you car. (ONLY because of ease of just driving up onto ramps) you can store on a two post too.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Car lift for your shop [Re: bobs69] #2106273
07/08/16 03:14 PM
07/08/16 03:14 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I store my car on my two post.
Re: Car lift for your shop [Re: Copper Dart] #2106325
07/08/16 05:28 PM
07/08/16 05:28 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
: iagree
The Ramcharger will be spending a lot of time on the 4 post as I need to box the frame for strength, just like in the picture below. After it will move on its own I will be using the lift for servicing the fleet. Another reason for the 4 post is that I live in earthquake country and I really don't need to store anything up high. My '64 Polara had its wheels off and was resting on four super duty jack stands when we had the Nisqually Quake and I expected it to be on the ground when I got home, but it was still on the stands. up
2008 Honda Element
Re: Car lift for your shop [Re: bobs69] #2106902
07/09/16 05:26 PM
07/09/16 05:26 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
How tall our your ceilings those with lifts? I plan to add a 20x 20 bay on my shop...me current ceiling is 10'... do I need to go 12'...14'..??
Only will store RR and Charger....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Car lift for your shop [Re: bobs69] #2106934
07/09/16 06:36 PM
07/09/16 06:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have a 14.00" Ceiling but if I could have gone to 16.00" I would have (city wouldn't allow a higher wall). 14.00" ceilings are fine for most anything inside on a lift, but with a 2 foot minimum for roll up doors it gives me a max door opening height of 12.00' which is boarder line for some of the taller RV's air conditioning units etc. Not an immediate issue, probably ever for me, but if I sell it all someday it could be one for a future owner.
Re: Car lift for your shop [Re: bobs69] #2106937
07/09/16 06:44 PM
07/09/16 06:44 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
I am looking at this one
https://www.eagleequip.com/product/MS-8000XLT.html
The measurement guide seems to show 12' ceiling will be fine... I wont have a door...its a drive in bay attached to my current shop...??
Re: Car lift for your shop [Re: JMCFAN] #2107577
07/10/16 11:27 PM
07/10/16 11:27 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I have that lift, and a BendPak HD9XW in my garage-which has a 10' 9" ceiling. Zero issues with a 1969 GTX in the bottom and a 1967 Newport on the top (on the BendPak). Plenty of extra clearance on the top and bottom.
For WIW, I would not buy that Eagle lift: buy a BendPak. Having both, it is CLEAR where the extra 1k went into the BendPak. I would never put my GTX or Newport on the Eagle.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Car lift for your shop [Re: EWJ] #2125385
08/05/16 12:53 AM
08/05/16 12:53 AM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
well I've heard a lot about shops but need more manufactures on 4 post lifts. Stopped in Warren Ohio today at Back yard buddy. I like the looks of there lifts. Pricey.. but showed me some bent ones in the back from other vendors. some of you guys seem to like the Bendpak. Cant get good pictures of the construction of them. Bendpak looks like the lock is hanging from one bolt at the top? not welded in place or anything, scares me. I like the fact of the back yard buddy has a tube around a tube vs a open 3 sided competitors. My old center post gave up the ghost. want this to store and work. want to stay with a 4 post. like that the back yard buddy is very stable when you grab it and push on it. so what other name bands you guys using? like the buddy but boy the price ! but you cant put a price on safety... thoughts on the lifts you all own.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Car lift for your shop [Re: bobs69] #2125606
08/05/16 12:04 PM
08/05/16 12:04 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
I don't have my own lift but plan on it eventually.
I did my apprenticeship at a Ford dealer and used both hoists. The 4 post was way more versatile. Depending on vehicle length and frame configuration the 2 post could just get sketchy getting it all set-up an finding the balance points.
Never dropped a car but it happens often enough. A 4 post with a set of jack trays on air was great. Plus when working the hoist gives a nice place to put your tools down.
https://youtu.be/rQj7Y7Q8tU4
Re: Car lift for your shop [Re: bobs69] #2262032
03/02/17 02:53 AM
03/02/17 02:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well, the lifts are in! I went with a local vendor, CEM Lifts in Post Falls Idaho. Very good service and fair pricing. I did plenty of homework and these two filled the bill for my needs. The 4 post is a Direct Pro Park 8 PLUS LONG 9,000lb ALI certified portable and will be used primarily for storage, the 2 post is a TLT210-A 10,000 Launch Tech and is also ALI certified. It could have been setup as either Asymmetrical or Symmetrical and I went with Symmetrical to give it more versatility.
Re: Car lift for your shop [Re: rowin4] #2262060
03/02/17 04:29 AM
03/02/17 04:29 AM
Manila Philippines
ashley Offline
ashley  Offline
Manila Philippines
this thing is a beauty...is this the same model car that vin diesel used on the fast and the furious movie?...
Re: Car lift for your shop [Re: rowin4] #2262132
03/02/17 12:33 PM
03/02/17 12:33 PM
moparx Offline
moparx  Offline
that's called FSS. Flat Surface Syndrome........ biggrin
beer
Re: Car lift for your shop [Re: ScottSmith_Harms] #2262169
03/02/17 01:49 PM
03/02/17 01:49 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
The ProPark 8 is the exact one I am looking at... saw it a Barrett J in Phoenix... Cant wait!!
Page 3 of 4 1 2 3 4
