Re: What do you want in a tubular K-frame?
[Re: 67autocross]
#2105133
07/06/16 07:23 PM
07/06/16 07:23 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Well keep the post going on the system as you build it for the E body, are you planning on keeping the factory upper control arm mounts or will it have them on the new suspension?
That is one of the questions I was asking in the original post. Would having to move the original location be a deal breaker? Are you open to possibly even installing a new shock tower piece? I need to know what you guys would want and what your willing to do to have the best handling or are you willing to compromise handling to keep the original upper mount?
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#2105137
07/06/16 07:31 PM
07/06/16 07:31 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I'm thinking that if one was to spring for your setup that going all out would be the expectation. I can't see spending serious money for a new suspension that may be compromised by keeping the factory UCA mounts, assuming that would be a compromise.
#2105293
07/06/16 10:51 PM
07/06/16 10:51 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
That is one of the questions I was asking in the original post. Would having to move the original location be a deal breaker? Are you open to possibly even installing a new shock tower piece? I need to know what you guys would want and what your willing to do to have the best handling or are you willing to compromise handling to keep the original upper mount? I'm speaking only for myself here, if I was buying this kind of system which I ASSume will be in the $6000 range I would be looking for the best possible handling and not if I have to cut the car up or not. The market has enough products for stock suspension and enough bolt in Mustang II kits...so if you are going to do it make sure you don't compromise or there will be no point in choosing what you offer over what is already available.
A new iron curtain drawn across the 49th parallel
#2105329
07/06/16 11:41 PM
07/06/16 11:41 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The B/E bodies suffer from the wrong upper A-arm mounting, so that would have to go IMO. A bodies are good there.
Mopar to the bone!!!
#2105558
07/07/16 11:40 AM
07/07/16 11:40 AM
Posts: 669 Los Osos, Ca
CKessel
Los Osos, Ca
Along with the arm mountings being wrong, how about the 60's/70's factory tolerances? This may be a way to get that corrected too.
Carl Kessel
#2105803
07/07/16 06:24 PM
07/07/16 06:24 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Just an observation from an Engineer with an MBA that likes to go fast as much as the next guy... You are essentially doing what XV did to some extent, from what I can see. The history that I know was they went belly-up and were bought-out from a previous employer. They aren't necessarily today's hottest suspension manufacturer with product flying off of the shelves....again, from what I can see at this vantage. Maybe they are and I am just not aware. With that in mind: The number of people racing Mopars is very low. The number of people racing Mopars at a highly-competitive level to necessitate drastic suspension changes is far lower. The number of people getting into racing Muscle Cars is not necessarily booming either. The target market here is minuscule, unfortunately. Basic business practices will tell you with that low of volumes, the cost will be high, margins will be low and it may not be as successful as you suspect. XV offers, to some extent, what you are talking about doing...and honestly...I can't remember the last time I have seen someone comment about owning an XV suspension system. You may be trying to solve a problem that there is no sustainable market for. The key here is bang-for-buck, walking the supply/demand curve to increase volumes. There has to be a target cost and level of variation you can withstand, you can easily hit a pricing threshold that will scare away the majority of those even looking at major suspension changes for these cars. An XV front system with front brakes is around $7,750 and I haven't even gotten it to my front door yet. Sure, it's probably as good as it gets today, but that is a significant amount for the small market that exists. I can buy what Hotchkis has today for the front for about $1,600, rebuild the steering box for $400 and put $1000 in front brakes [~$3,000]. I can take that box of parts, install it over a weekend and go be pretty-darn competitive. Somewhere along the line someone has to be convinced to spend 158% more to go to XV. What can you do to convince that small market your product is worth "X" amount more? What will you have to convince that small market you are better than Option A or B, your direct competition? I know my post wasn't warranted, but I wanted to throw it out there...
#2105810
07/07/16 06:33 PM
07/07/16 06:33 PM
DaytonaTurbo
Manitoba, Canada
That is one of the questions I was asking in the original post. Would having to move the original location be a deal breaker? Are you open to possibly even installing a new shock tower piece? I need to know what you guys would want and what your willing to do to have the best handling or are you willing to compromise handling to keep the original upper mount? If you're looking for some inspiration, the 73+ B bodies had the upper control arm and shock mounts as part of the k-frame. With that system, relocation would be easier IMO.
[Re: GoodysGotaCuda]
#2105831
07/07/16 07:17 PM
07/07/16 07:17 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I can buy what Hotchkis has today for the front for about $1,600, rebuild the steering box for $400 and put $1000 in front brakes [~$3,000]. I can take that box of parts, install it over a weekend and go be pretty-darn competitive. You have many great points Goody I agree as well. I have done this and my `Cuda only handles as good as my beater Corolla. I drive my muscle car not because its faster around a corner but rather its more fun and satisfying driving a slow car fast. For precision handling I drive my S2000. Another reason I stuck to stock type suspension besides cost is because of the durability. I would like to see a Mopar with an aftermarket tubular K frame setup survive all the jumps the black 68 Charger does in the movie Bullit and only then will I be impressed.
#2105839
07/07/16 07:29 PM
07/07/16 07:29 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Just an observation from an Engineer with an MBA that likes to go fast as much as the next guy... You are essentially doing what XV did to some extent, from what I can see. The history that I know was they went belly-up and were bought-out from a previous employer. They aren't necessarily today's hottest suspension manufacturer with product flying off of the shelves....again, from what I can see at this vantage. Maybe they are and I am just not aware. With that in mind: The number of people racing Mopars is very low. The number of people racing Mopars at a highly-competitive level to necessitate drastic suspension changes is far lower. The number of people getting into racing Muscle Cars is not necessarily booming either. The target market here is minuscule, unfortunately. Basic business practices will tell you with that low of volumes, the cost will be high, margins will be low and it may not be as successful as you suspect. XV offers, to some extent, what you are talking about doing...and honestly...I can't remember the last time I have seen someone comment about owning an XV suspension system. You may be trying to solve a problem that there is no sustainable market for. The key here is bang-for-buck, walking the supply/demand curve to increase volumes. There has to be a target cost and level of variation you can withstand, you can easily hit a pricing threshold that will scare away the majority of those even looking at major suspension changes for these cars. An XV front system with front brakes is around $7,750 and I haven't even gotten it to my front door yet. Sure, it's probably as good as it gets today, but that is a significant amount for the small market that exists. I can buy what Hotchkis has today for the front for about $1,600, rebuild the steering box for $400 and put $1000 in front brakes [~$3,000]. I can take that box of parts, install it over a weekend and go be pretty-darn competitive. Somewhere along the line someone has to be convinced to spend 158% more to go to XV. What can you do to convince that small market your product is worth "X" amount more? What will you have to convince that small market you are better than Option A or B, your direct competition? I know my post wasn't warranted, but I wanted to throw it out there... You are 100% correct. I am building a setup for just one customer, so unfortunately, he absorbs the design and fab cost. He is fine with that. I am just trying to determine if I want to build a production jig or a simple one off jig to build his parts. If I do the production jig and had a few people that wanted one, I'd cut my customer a little slack on price and spread it out evenly. This is Mopar stuff. I know there will never be a large market, and more importantly, not much profit. I'm fine with that. Doing this kind of stuff and working on the older cars really has no bearing on my main business, so call it. "just for the fun of it". I have NO intentions of going into the suspension business, just as I have NO intentions of ever doing another LX conversion. I did it, it was cool, and I'm done. If I make just the one, I'm happy.
#2105924
07/07/16 10:14 PM
07/07/16 10:14 PM
Posts: 22,724 Bitopia
jcc
Bitopia
The MBA is correct on a few points, except the problem I saw was with XV was over marketing, mainly they promoted their system as being super fine tuned with more post testing then I can count, but when it came down to it, a lot of the system were generic, you can't have "finely tuned suspension" that fits every car, and costs a small fortune, and then get defensive with your market when they want some technical answers. I believe there is a market for high end niche clientele. The MBA will kick in when the development costs are absorbed in the initial prototype, and the solution then can be offered to an increasingly wider market as production slowly ramps up and costs decrease. Keeping it pricey does make it more desirable in many cases. It costs more, it must be better, can't wait till my tax refund check shows up mentality. The best feature hopefully, is better performance. The downside, it can't be a universal solution to fit everyone's combination, and if does, it will be a big compromise, and just join all the other garage produced RMS iterations over the past decade. What I am feeling here, this will be the real deal, by someone that is willing to follow thru. And the more its attempted to be copied by others, all the more proof it is the real deal.
#2107184
07/10/16 09:24 AM
07/10/16 09:24 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would like to see the ability to use the z06 calipers and rotors, so custom spindles that would accept the Brembo Calipers and carbon fiber rotors...saves a lot of weight and mega stopping ability. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
