What Trans options are to back the Gen3 Hemis that will allow NO floor sheet metal modifications? What can be used with the stock console and floor shifter (Auto)
What are the Manual options? Again still retaining a stock look on the inside?
A41 4spd auto, .070 OD from SST/Silver Sport Transmissions, no floor mods, tranny crossmember is a bolt in, factory slap stick retained, complete kit from bellhousing to driveshaft, converter, flexplate, speedo cable, tranny crossmember, mount, tranny lines, controller to program shift points/lock up, depending on what HP/Torque model you choose your going to drop $4500-$6500
You might want to check out their 6spd T56 Tremec E body conversion as well...
