Re: 1970 Lynch Road fender tag help and info please
[Re: C_stripes]
#2104870
07/06/16 01:01 PM
07/06/16 01:01 PM
Posts: 349 Mid west
C_stripes
Mid west
So no one will help because I didn't post a pic of my tag? I want to learn, thats all.
Is there any website that shows how to read them?
[Re: C_stripes]
#2104876
07/06/16 01:07 PM
07/06/16 01:07 PM
Posts: 129 fargo,nd
fk5hemi
fargo,nd
So no one will help because I didn't post a pic of my tag? I want to learn, thats all. Most times you have to give something to get something.
[Re: C_stripes]
#2105077
07/06/16 06:09 PM
07/06/16 06:09 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
here's a good start to understand '70 Lynch Rd. (or an assembly plant in general) building the Superbird the gate/base number refers to the fixtures at the plant used to construct the uni-body different plants did some things in different ways Lynch Rd. used the last 3-digits of the 7-digit "ENGINE/TRANSMISSION/AXLE assembly part number" on their fender tags, this same info is on a broadcast sheet N = 383 4bbl (& is included as part of the VIN) E63 = 383 4bbl xxxx 089 = orange engine assembly for B/E-body - 383HP 4bbl (335hp) with A/C & Holley carb. for automatic transmission or xxxx 088 = orange engine assembly for B/E-body - 383HP 4bbl (335hp) w/Holley carb. for automatic transmission etc.
[Re: C_stripes]
#2106687
07/09/16 03:39 AM
07/09/16 03:39 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
... Why do they have the engine code on there three times (E63, N, 088)?
Good question... Three different formats for the same info. E63 is a sales code for 383-4bbl N is administrative and 'short hand' for 383-4bbl. In this format, tell only tell you the 'what'; the car got a 383-4bbl. 088 is an assembly code and tells you the 'which'. It tells you which 383-4 engine the car actually received.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
