Re: Buying this 1970 wrecked truck, what years interchange?
[Re: wyldebill]
#2104075
07/05/16 03:34 AM
07/05/16 03:34 AM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
Any push button door handle door, should work. But all 61-71 will bolt on, I believe Thats what I thought when I built my 67 Power wagon and swapped out the front clip and short bed with a 63. The doors were different on the jam area where they close. Im sure the front clips are find but the doors I think only fit particular years. RUMBLON
[Re: poorboy]
#2105380
07/07/16 01:04 AM
07/07/16 01:04 AM
Posts: 43,650 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
The doors will bolt on from 61-66 but latches will be different, use a 67-71 door it will be much easier. Check out sweptline.org for more info on hacking it into a shortbed.
JB Rhinehart, Realist
A-Body's RULE!
[Re: bbtrux]
#2109842
07/14/16 11:31 AM
07/14/16 11:31 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
The latches were different pre 68 also.Dont bolt into the door the same. Pre 67.
1970 Dodge d100/eventually going on a 77 D100 frame
