1970 Cuda drivers side fresh air vent cable routing
#2100618
06/29/16 05:43 PM
06/29/16 05:43 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
Hi Guys,
Does anyone have a picture or description of the routing of the driver side fresh air vent cable on a 4 speed 70 cuda... i can't recall how it makes its way past the pedals and over center spring.
thanks
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
Re: 1970 Cuda drivers side fresh air vent cable routing
[Re: smac77]
#2103592
07/04/16 01:53 PM
07/04/16 01:53 PM
smac77
Caledon, Ontario
Anyone ? Cable is too short to route around the pedal and spring... and I see a hole in the pedal bracket but it seems to small to get the end through...
[Re: smac77]
#2103780
07/04/16 06:24 PM
07/04/16 06:24 PM
smac77
Caledon, Ontario
figured it out... for any one else looking in the future.. this cable routes up over top of the back side of the pedal assembly.There is just enough of a slot between the pedal assembly and cowl.. Gets hung up on the insulation when fishing it so I recommend installing before the dash !
