ARC 8000 switch panel HELP!!!!! #2103315
07/03/16 11:23 PM
07/03/16 11:23 PM
Janesville, WI
SpareParts Offline OP
Janesville, WI
I have power to the panel and it's lit up but none of the switches work! Everything worked before then I turned car off, pulled battery and it sat 3 weeks. Trying to start again and now this problem. I have 12.7 volts, and I installed battery then turned main power on.
What am I missing?
Re: ARC 8000 switch panel HELP!!!!! [Re: SpareParts] #2103317
07/03/16 11:26 PM
07/03/16 11:26 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Do you have the ground hooked up to the relay panel?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: ARC 8000 switch panel HELP!!!!! [Re: SpareParts] #2103329
07/03/16 11:47 PM
07/03/16 11:47 PM
Janesville, WI
Janesville, WI
I need a new data cable... who has one they can ship ASAP? Really wanted to go to a friend's memorial car show Wednesday night.
I'm begging!
Re: ARC 8000 switch panel HELP!!!!! [Re: SpareParts] #2103343
07/04/16 12:11 AM
07/04/16 12:11 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I have one you can borrow. You're talking about the ribbon right?
SDG Motorsports
Re: ARC 8000 switch panel HELP!!!!! [Re: SpareParts] #2103522
07/04/16 12:24 PM
07/04/16 12:24 PM
Janesville, WI
Janesville, WI
Good news if you have one of these, you can pop the pin connector off one side and crimp it back further, mine pulled out at the very end. It's fixed now. Hope this helps someone someday
Re: ARC 8000 switch panel HELP!!!!! [Re: SpareParts] #2103559
07/04/16 01:09 PM
07/04/16 01:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Good info
