indy 440-1 nut size
#2103200
07/03/16 06:56 PM
07/03/16 06:56 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I'm struggling to get my 3/8 deep socket on the lower row of nuts on my heads, any suggestions ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: indy 440-1 nut size
[Re: deaks]
#2103443
07/04/16 06:17 AM
07/04/16 06:17 AM
deaks
robin hood country
Sorry Cab, i meant i'm using a 3/8 drive socket, no they are 6 point and yes they are 7/16". Fastmop The socket i'm using is fairly slim and i thought it might compromise the strength if i sanded much off it. I see three options, sand a bit of the head back for access, sand a socket right down and hope it doesn't break, or change that row of studs on both heads for bolts with smaller heads, or nuts with smaller heads, maybe 12 point if they are smaller. Mick
[Re: deaks]
#2103539
07/04/16 12:37 PM
07/04/16 12:37 PM
deaks
robin hood country
I've just been loking on ARP's site and the 12 pt nuts are 9/16 socket, so that will probably solve the problem. I'm assuming they are 7/16-20 nuts ? Mick
[Re: deaks]
#2103829
07/04/16 07:32 PM
07/04/16 07:32 PM
deaks
robin hood country
Thanks, i've ordered the 1/2" drive nuts, just hope i can use the existing washers. Mick
