DBL beadlocks on a dana 60 #2102471
07/02/16 01:29 PM
07/02/16 01:29 PM
Great Neck,LI,new york
hemi-itis Offline OP
Thought I'd share my currant frustration.Double beadlock rims will NOT fit over a finned dana 60 drum mad
There is a smoothie non finned drum but they want prices that are double on flea-bay.Will try to machine the drums down and make it work or I have to install discos sooner than planned frown
If someone has a set lemmie know smoke
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2102476
07/02/16 01:42 PM
07/02/16 01:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Put Willwoods on it. It will stop so much better
Re: DBL beadlocks on a dana 60 [Re: FastmOp] #2102507
07/02/16 02:54 PM
07/02/16 02:54 PM
fullmetaljacket Offline
you'll be lighter with Wilwoods.
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2102524
07/02/16 03:44 PM
07/02/16 03:44 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
two suggestions for Wilwoods, yet when you ask a brake question most say "pass". Just an observation. I have wilwoods on the front and DO need better in the rear than the drums.
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2102566
07/02/16 04:49 PM
07/02/16 04:49 PM
How about switching to the 10.5x2.5 inch drums and backing plates, maybe with forklift linings devil The stockers use to use the really soft forklift linings with 9x3 inch brakes on the rears foot braking work up
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2102681
07/02/16 09:19 PM
07/02/16 09:19 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
You have a car that makes enough power you need beed locks and your stopping with heavy drum brakes???
JAKES AUTOMOTIVE
Re: DBL beadlocks on a dana 60 [Re: JAKE68] #2102832
07/03/16 03:08 AM
07/03/16 03:08 AM
In order to match my rear rims I had to get a Bead Lock rim with the option of a DBL,so I bought the DBL.I am not fast enough to NEED them.
Champion said my rear rims were "collector items"
Re: DBL beadlocks on a dana 60 [Re: Cab_Burge] #2102869
07/03/16 09:23 AM
07/03/16 09:23 AM
moparx Online content
moparx  Online Content
cab, tell us more about those forklift linings. do they come in just the lining you can rivet on your shoes, or is there a possible shoe set for the 10" brakes ? what are they made of ? are the linings thicker than the stock material ? and lastly, what size and approximately what year range of fork lift should a guy be looking at for this material ?
beer
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2102884
07/03/16 10:12 AM
07/03/16 10:12 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Some of the wilwood brakes wont fit a 15 beadlocker either. Strange brakes are lighter, smaller, and won't get sticky like the wilwoods. athat is of course if you go aftermarket.
Re: DBL beadlocks on a dana 60 [Re: dthemi] #2102958
07/03/16 12:23 PM
07/03/16 12:23 PM
D,,,which other brands fit??? I'll find out Tuesday if the lathe worked panic
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2103057
07/03/16 02:45 PM
07/03/16 02:45 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I have installed more sets of Wilwood brakes than I can count and never had an issue with a single set. Have also used Strange, Mark Williams and Lambs with no problems. Aero-Space on the other hand.........well lets just say I wouldn't buy anything they make.
As far as clearing beadlocks. Some wheels clear, some don't, but it's not the caliper, it's the beadlock ring. I have never had a set of Champions, that would NOT clear the Wilwood 4 piston calipers. Close yes.......hit no
This day and time, no way anything resembling fast, should have drums on the rear. With the steady pressure brakes require to stop a race car in the shutdown from any decent speed, the drums fade QUICK. That means you are doing all your stopping on the front brakes, that has the tiny tire. Bad plan.
Doesn't really matter what guys USED to do and it worked OK. Fact is, it really did NOT work well back then and still won't. They just managed to get by and not crash or run off a track
Re: DBL beadlocks on a dana 60 [Re: moparx] #2103081
07/03/16 03:42 PM
07/03/16 03:42 PM
You will need to take a set of good shoes, no metal to metal contact on them tsk to a comercial brake relining company, not a parts store, and have them use thier softest lining thumbs scope Make sure and tell them this is for a non street car also, maybe a show car whistling
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2103091
07/03/16 03:59 PM
07/03/16 03:59 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Re: DBL beadlocks on a dana 60 [Re: Cab_Burge] #2103108
07/03/16 04:30 PM
07/03/16 04:30 PM
interesting ! thanks cab ! up
beer
Re: DBL beadlocks on a dana 60 [Re: JAKE68] #2103134
07/03/16 05:11 PM
07/03/16 05:11 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Lol
Mopar Performance
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2103261
07/03/16 09:25 PM
07/03/16 09:25 PM
Thank you all for your replies bow I want to drive it NOW,I hit 2 or 3 cruze nights every week.Not too much to miss this weekend with all the firework shows.
As many know,my daughter is getting married in 2 weeks,,,,,,ya know,,the Carlisle weekend that I normaly go for 4 days.......so ALL extra funds are getting funneled in her direction.When I get caught up I can look into rear disc maybe with an E brake with them work
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2103397
07/04/16 01:54 AM
07/04/16 01:54 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The strange brakes give you the most clearance. They're light and they don't corrode in the piston seal area like the wil's. Strange has a complete kit that's less cost than the wil's too.
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2103449
07/04/16 08:30 AM
07/04/16 08:30 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I like my strange brakes
Mopar Performance
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2106131
07/08/16 10:13 AM
07/08/16 10:13 AM
Machined the drums,worked out FINE!!
Re: DBL beadlocks on a dana 60 [Re: hemi-itis] #2106150
07/08/16 11:01 AM
07/08/16 11:01 AM
up how much did you take off, how much clearance do you have now between wheel and drum, and what was the final diameter ?
beer
