462 Hemi, Whats your take on FI and 6.1 intake with boost? Would you be better to keep the cubes down?
If you mean fuel injection vs carb'd.......I would go carburated all the way unless running turbos or a centrifugal supercharger. The stock intake manifold works very well with boost. Yes, I would def keep the cubes smaller. Mainly so I could keep the piston compression height
As tall as possible. At minimum something in the 1.22 compression height. That is the stock compression height of the 6.4 motor.. My other car i run a stock hellcat shortblock in and it is 378". I run twin Borg Warner 66mm turbos with it. With boost, the main thing you want is for it to live, so cubes don't become nearly important like a naturally aspirated motor.
