EGR cooler and valve, CCV filter maintenance #2102426
07/02/16 11:18 AM
07/02/16 11:18 AM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
2007 Dodge Ram 2500 6.7 cummins
just hit 67,500 miles and "perform service" indicator is now on.
I read that this is indicating I need to clean the EGR cooler and valve and replace the CCV filter.
Questions;
1) Where did you guys get the EGR cleaner fluid from ? dealer ? other ?
2) What about the gaskets and small o-rings that will need replacement when i put the cooler and valve back on ? ( parts store ? dealer ? )
3) Where did you get your CCV filter from ?
thx for any help....
Doug smoke
Re: EGR cooler and valve, CCV filter maintenance [Re: 69CHARGERMD] #2102504
07/02/16 02:47 PM
07/02/16 02:47 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Geno's garage will have what you need to clean your EGR system and replacement CCV filter. Or you could just delete your truck and never have to mess with that crap again...
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: EGR cooler and valve, CCV filter maintenance [Re: 69CHARGERMD] #2102585
07/02/16 05:28 PM
07/02/16 05:28 PM
KENTUCKY
KENTUCKY
Thanks 71 !!
I couldn't recall Genos garage,,,,,I think I purchased from them before,,,,,
Thank you
Re: EGR cooler and valve, CCV filter maintenance [Re: 69CHARGERMD] #2102602
07/02/16 05:59 PM
07/02/16 05:59 PM
Missouri U.S.A.
Missouri U.S.A.
Anytime. up
10.02@134
