Small block head bolts #2101783
07/01/16 11:52 AM
07/01/16 11:52 AM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
What's the lenght of the head bolts for a 318 LA engine?
Re: Small block head bolts [Re: kimber] #2102006
07/01/16 05:21 PM
07/01/16 05:21 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
4" for the long ones and 2.5" or 3" for the shorter ones.
I couldn't get the shorter ones out without taking off the exhaust manifold so I guessed at those.
I have mechanical Aptitude.
I can screw up anything.
Re: Small block head bolts [Re: bboogieart] #2102030
07/01/16 05:57 PM
07/01/16 05:57 PM
3&9/16" for the (8) medium ones. 1&31/32" for the (10) short ones. 4&19/32" for the (2) long ones. shank dimention only
Re: Small block head bolts [Re: RapidRobert] #2102072
07/01/16 07:36 PM
07/01/16 07:36 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I tip my hat to you sir.
How is that measured?
From the bottom of the head?
Re: Small block head bolts [Re: bboogieart] #2102123
07/01/16 09:32 PM
07/01/16 09:32 PM
now that you mention it the heads on some of em in my pile of 20 going on my next build may have different height of heads on some of em (the short ones iirc) but I wasn't thinking of that when I measured em but I did notice the heads looked different (wider/maybe taller), I just measured the shank as that is the important dimention to get enough clamping. you have a bit of leeway there as the ends ain't dead square so I measured what I saw
