Page 2 of 3 1 2 3
Re: 440 Iron head build only [Re: DARTH V8Я] #2106673
07/09/16 02:26 AM
07/09/16 02:26 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By DARTH V8Я
^^^ yeah goes no Mopar, ever, in all time has ever went fast or made 400hp with iron heads. rolleyes
Foul, moving the goalposts. Changing the goal for 500-550 to 400 hp. Here are a couple of iron head builds by fast68plymouth Default 500/525 hp 440 from the Tech Archives Default 500 hp build form the Tech Archives
Re: 440 Iron head build only [Re: JohnRR] #2247405
02/04/17 10:13 PM
02/04/17 10:13 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
I have never heard of acid porting? How does that work?
Re: 440 Iron head build only [Re: JohnnyBeGood] #2247415
02/04/17 10:23 PM
02/04/17 10:23 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Re: 440 Iron head build only [Re: JohnnyBeGood] #2247418
02/04/17 10:27 PM
02/04/17 10:27 PM
Acid porting is usually used to cover up grinding and real porting work done with carbide bits shruggy It makes the cast iron look like porous cast iron again shruggy
Re: 440 Iron head build only [Re: Cab_Burge] #2247482
02/05/17 12:16 AM
02/05/17 12:16 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Cheating grin
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: 440 Iron head build only [Re: JohnnyBeGood] #2250944
02/10/17 11:16 AM
02/10/17 11:16 AM
Central NC
gch Offline
gch  Offline
Central NC
Only if you get caught.
Re: 440 Iron head build only [Re: gch] #2251109
02/10/17 04:39 PM
02/10/17 04:39 PM
up That be true work
Re: 440 Iron head build only [Re: JohnnyBeGood] #2251131
02/10/17 05:08 PM
02/10/17 05:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I have four sets of iron heads being done here at the shop right now, and another set on the way.
Iron still lives on!! smile
3 sets need to be iron for what the owners are doing with the cars, another set doesn't "have to" be, but really "should" be....... The last set, they wouldn't really need to be, and if it were my decision, I'd probably use stealth heads on it, but the car owner wants to use the original heads.
Re: 440 Iron head build only [Re: fast68plymouth] #2251213
02/10/17 07:33 PM
02/10/17 07:33 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
not every application needs aluminum heads and/or stroker kits, but online people will gladly spend your money for you
Re: 440 Iron head build only [Re: JohnnyBeGood] #2251267
02/10/17 09:26 PM
02/10/17 09:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
Rarely is it less expensive to rework iron heads than buy aluminum, if there are "budget friendly" aluminum heads available for what you're building....... And that's the case for BB mopars for sure.
Oh, and I had forgotten about one set....... So, 5 sets here, another set on the way smile
Re: 440 Iron head build only [Re: JohnnyBeGood] #2251289
02/10/17 10:04 PM
02/10/17 10:04 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I always get a Kick out of the reply's in threads like these. Here the topic of the thread is "440 Iron Head Build Only" The next time I'm at the mall and see someone making a wish and throwing their hard earned coins into the fountain... I'm going to let them do it...Despite what Moparts has taught me
My advice to the original poster is to call the guy with 5 sets of iron heads in his shop.
Re: 440 Iron head build only [Re: JohnnyBeGood] #2251701
02/11/17 04:55 PM
02/11/17 04:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
That reminded me....... There's actually 6 sets here...... and another on the way. wink
Oh, and that's just the Mopar heads.
I'm not sure if iron hemi heads count, but if so..... Then add another set.
Got a few others of some different make iron stuff here as well..... And more on the way.
I don't mind working on them at all.
As long as the person having them done understands that quality work takes time...... And time is $$$$.
Re: 440 Iron head build only [Re: fast68plymouth] #2252120
02/12/17 10:03 AM
02/12/17 10:03 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I'm one of the few guys that still thinks there is a place, albeit limited, for iron heads. If you are looking for max power without other personal choice restrictions, iron seems silly.
But, if you are in the 500 hp or less bucket you simply don't need aluminum after market either. I am not an anti-Chinese guy, but if I can reach my goal with iron, and pay a local guy (my first choice) or a domestic guy $1600 to do work, that will be a serious consideration for me. In this power range, it is the weight savings that puts me on the fence.
Re: 440 Iron head build only [Re: JohnnyBeGood] #2252264
02/12/17 02:21 PM
02/12/17 02:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
The weight, and the cost/ease of getting good quench........since there are far more open chamber heads than closed for the iron lovers to use.
Re: 440 Iron head build only [Re: JohnRR] #2603517
01/08/19 05:49 PM
01/08/19 05:49 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Originally Posted By JohnRR
I have some crazy modified stock iron intakes too, one from fast68plymouth ... and one that was acid ported ...
You got pictures of that?
Moparlee
Re: 440 Iron head build only [Re: Robbins] #2720145
11/28/19 07:40 PM
11/28/19 07:40 PM
CT
roadrunner2 Offline
roadrunner2  Offline
CT
Two years later, John, and I’d like to see those pictures now.
Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’
Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST.
10:1 451” replaced with 14:1 499”.
Re: 440 Iron head build only [Re: roadrunner2] #2720235
11/29/19 12:11 PM
11/29/19 12:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
Not work I did, but here’s a couple of pics of a low deck intake that is being used in FAST & Super Car.
Re: 440 Iron head build only [Re: fast68plymouth] #2720239
11/29/19 12:45 PM
11/29/19 12:45 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Looks nice... I wonder if the same treatment would benefit my Edelbrock RPM air-gap too? work
There are some recommendations out there to cut the divider down to near the floor...
Edited to add: https://board.moparts.org/ubbthread...ove-divider-on-a-two-plane-manifold.html
There does not seem to be a firm consensus.
Re: 440 Iron head build only [Re: fast68plymouth] #2720258
11/29/19 02:45 PM
11/29/19 02:45 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I thought I read where folks tried this mod amd hurt it. Cool if it works.
Moparlee
Re: 440 Iron head build only [Re: Robbins] #2720626
12/01/19 01:17 PM
12/01/19 01:17 PM
So. Burlington, Vt.
So. Burlington, Vt.
I can tell you that the intake in the pics ended up that way thru testing in the car at the track.
Page 2 of 3 1 2 3
